1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Error in ADSimDetector (areaDetector) compilation
From: Martín Marín Vilches via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 18 Jan 2023 09:26:50 +0100
I've been trying to build SynApps but the build fails at some point while compiling the ADSimDetector module in areaDetector. I've looked at the error for a while and I don't really know what's causing it. It looks to me like a problem with the folder MakeFiles but this is my first time working on it so I'm not really sure.
I'm using version R3-11 of areaDetector and here is the last part of the make output:
make -C /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector install
make[2]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector'
make -C ./configure install
make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure'
perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure/O.linux-x86_64'
perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure/O.linux-x86_64'
make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/configure'
make -C ./simDetectorApp install
make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp'
make -C ./src install
make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src'
perl -CSD /home/martin/EPICS/epics-base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include     -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include        -MM -MF simDetector.d  ../simDetector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include     -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include        -c ../simDetector.cpp
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = signed char]’:
../simDetector.cpp:624:46:   required from here
../simDetector.cpp:68:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare]
   68 |                 for (i=0; i<arrayInfo_.nElements; i++) {
../simDetector.cpp:72:28: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare]
   72 |                 for (i=0; i<arrayInfo_.nElements; i++) {
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = unsigned char]’:
../simDetector.cpp:627:47:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = short int]’:
../simDetector.cpp:630:47:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = short unsigned int]’:
../simDetector.cpp:633:48:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = int]’:
../simDetector.cpp:636:47:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = unsigned int]’:
../simDetector.cpp:639:48:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = long long int]’:
../simDetector.cpp:642:47:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = long long unsigned int]’:
../simDetector.cpp:645:48:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = float]’:
../simDetector.cpp:648:49:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeArray(int, int) [with epicsType = double]’:
../simDetector.cpp:651:49:   required from here
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = signed char]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = signed char]’
../simDetector.cpp:225:20: warning: comparison of integer expressions of different signedness: ‘int’ and ‘size_t’ {aka ‘long unsigned int’} [-Wsign-compare]
  225 |         for (i=0; i<arrayInfo_.nElements; i++) {
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = unsigned char]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = unsigned char]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = short int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = short int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = short unsigned int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = short unsigned int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = unsigned int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = unsigned int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = long long int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = long long int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = long long unsigned int]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = long long unsigned int]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = float]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = float]’
../simDetector.cpp: In instantiation of ‘int simDetector::computeLinearRampArray(int, int) [with epicsType = double]’:
../simDetector.cpp:94:55:   required from ‘int simDetector::computeArray(int, int) [with epicsType = double]’
/usr/bin/ar -rc    libsimDetector.a     simDetector.o
/usr/bin/ranlib libsimDetector.a
/usr/bin/g++ -o libsimDetector.so  -shared -fPIC -Wl,-hlibsimDetector.so -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/lib/linux-x86_64 -L/home/martin/EPICS/epics-base/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -L/home/martin/EPICS/support/synApps/support/asyn-R4-42/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/epics-base/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/lib/linux-x86_64 -Wl,-rpath,/home/martin/EPICS/support/synApps/support/asyn-R4-42/lib/linux-x86_64          -rdynamic -m64          simDetector.o   -lADBase -lasyn -lntndArrayConverter -lnt -lpvDatabase -lpvAccess -lpvData -lnetCDF -lnanohttp_stream -lMagick++ -lcoders -lMagick -ljbig -ljp2 -lbzlib -lpng -lwebp -llcms -lttf -lwmf -lfilters -ltiff -lxml2 -lNeXus -lhdf5 -lhdf5_hl -lbitshuffle -lblosc -lszip -lzlib -ljpeg -ldbRecStd -ldbCore -lca -lCom  -lX11 -lXext -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../lib/linux-x86_64/libsimDetector.so
Installing library ../../../lib/linux-x86_64/libsimDetector.a
make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src/O.linux-x86_64'
make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/src'
make -C ./Db install
make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db'
mkdir -p O.Common
make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[5]: Nothing to be done for 'install'.
make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db/O.linux-x86_64'
make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/Db'
make -C ./op install
make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/op'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp/op'
make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/simDetectorApp'
make -C ./iocs install
make[3]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs'
make -C ./simDetectorNoIOC install
make[4]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC'
make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure'
mkdir -p O.Common
make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure/O.linux-x86_64'
make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/configure'
make -C ./simDetectorNoIOCApp install
make[5]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/configure/RULES_USER
make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[6]: *** No rule to make target '/home/martin/configure/RULES_USER'.  Stop.
make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../configure/CONFIG_SITE.linux-x86_64.Common
make[6]: *** No rule to make target '../configure/CONFIG_SITE.linux-x86_64.Common'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64.Common
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64.Common'.  Stop.
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.linux-x86_64'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64.
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64.'.  Stop.
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.linux-x86_64'.  Stop.
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/CONFIG_SITE.local.'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/support/synApps/support/configure/CONFIG_SITE.linux-x86_64.
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/configure/CONFIG_SITE.linux-x86_64.'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/configure/CONFIG_USER.linux-x86_64
make[6]: *** No rule to make target '/home/martin/configure/CONFIG_USER.linux-x86_64'.  Stop.
make[6]: *** No rule to make target '/home/martin/configure/CONFIG_USER'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/epics-base/configure/os/CONFIG_SITE.UnixCommon.Common
make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/os/CONFIG_SITE.UnixCommon.Common'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/epics-base/configure/CONFIG_SITE.local
make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/CONFIG_SITE.local'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64.Common
make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64.Common'.  Stop.
make[6]: *** No rule to make target '/home/martin/EPICS/epics-base/configure/RELEASE.linux-x86_64'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../configure/RELEASE.linux-x86_64.Common
make[6]: *** No rule to make target '../configure/RELEASE.linux-x86_64.Common'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../configure/RELEASE.local
make[6]: *** No rule to make target '../configure/RELEASE.local'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../RELEASE.local
make[6]: *** No rule to make target '../RELEASE.local'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../../../../../RELEASE.linux-x86_64.local
make[6]: *** No rule to make target '../../../../../RELEASE.linux-x86_64.local'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  ../../../../../RELEASE.local
make[6]: *** No rule to make target '../../../../../RELEASE.local'.  Stop.
make -f ../Makefile TOP=../../.. T_A=linux-x86_64  /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/RELEASE_PRODS.local.linux-x86_64
make[6]: *** No rule to make target '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/configure/RELEASE_PRODS.local.linux-x86_64'.  Stop.
make[6]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
mkdir -p O.Common
make[7]: Entering directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall    -DUSE_TYPED_RSET  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I../../../../../include      -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include     -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include  -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include/os/Linux -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include   -I/home/martin/EPICS/support/synApps/support/busy-R1-7-3/include   -I/home/martin/EPICS/support/synApps/support/calc-R3-7-4/include   -I/home/martin/EPICS/support/synApps/support/seq-2-2-9/include   -I/home/martin/EPICS/support/synApps/support/sscan-R2-11-5/include  -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include/os/Linux -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include   -I/home/martin/EPICS/support/synApps/support/alive-R1-3-1/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADPluginEdge/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include        -MM -MF simDetectorNoIOC.d  ../simDetectorNoIOC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall    -DUSE_TYPED_RSET  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I../../../../../include      -I/home/martin/EPICS/support/synApps/support/asyn-R4-42/include     -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include/os/Linux -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSupport/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADCore/include  -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include/os/Linux -I/home/martin/EPICS/support/synApps/support/autosave-R5-10-2/include   -I/home/martin/EPICS/support/synApps/support/busy-R1-7-3/include   -I/home/martin/EPICS/support/synApps/support/calc-R3-7-4/include   -I/home/martin/EPICS/support/synApps/support/seq-2-2-9/include   -I/home/martin/EPICS/support/synApps/support/sscan-R2-11-5/include  -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include/os/Linux -I/home/martin/EPICS/support/synApps/support/iocStats-3-1-16/include   -I/home/martin/EPICS/support/synApps/support/alive-R1-3-1/include   -I/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADPluginEdge/include -I/home/martin/EPICS/epics-base/include/compiler/gcc -I/home/martin/EPICS/epics-base/include/os/Linux -I/home/martin/EPICS/epics-base/include        -c ../simDetectorNoIOC.cpp
make[7]: *** No rule to make target '../../../lib/linux-x86_64/libopencv_core.a', needed by 'simDetectorNoIOCApp'.  Stop.
make[7]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src/O.linux-x86_64'
make[6]: *** [/home/martin/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[6]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp/src'
make[5]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
make[5]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC/simDetectorNoIOCApp'
make[4]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: simDetectorNoIOCApp.install] Error 2
make[4]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs/simDetectorNoIOC'
make[3]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: simDetectorNoIOC.install] Error 2
make[3]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector/iocs'
make[2]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: iocs.install] Error 2
make[2]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector'
make[1]: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: /home/martin/EPICS/support/synApps/support/areaDetector-R3-11/ADSimDetector.install] Error 2
make[1]: Leaving directory '/home/martin/EPICS/support/synApps/support/areaDetector-R3-11'
make: *** [/home/martin/EPICS/epics-base/configure/RULES_DIRS:85: /home/martin/EPICS/support/synApps/support/areaDetector-R3-11.install] Error 2
Prev: Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4 Andrew Johnson via Tech-talk
Next: Re: How to use epicsThreadSetCPUaffinity in epics 7.0.4 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: **LAST CHANCE TO REGISTER** EPICS Code-a-thon Collaboration Workshop - Book your space today Diamond Events via Tech-talk
Next: Re: Tech-talk Digest, Vol 16, Issue 712 William F Badgett Jr via Tech-talk
