Send Tech-talk mailing list submissions to
tech-talk at aps.anl.gov
To subscribe or unsubscribe via the World Wide Web, visit
https://urldefense.proofpoint.com/v2/url?u=https-3A__mailman.aps.anl.gov_mailman_listinfo_tech-2Dtalk&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=TmOxd9LEM2p3Idbj7H58XVsFRnBlW4aab9p3yuHVBwI&e=
or, via email, send a message with subject or body 'help' to
tech-talk-request at aps.anl.gov
You can reach the person managing the list at
tech-talk-owner at aps.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. Phoebus Alarm Server on CentOS 9? (William F Badgett Jr)
2. Re: Ways to know if instrument connected via TCP/IP through
StreamDevice has lost connection (Wang, Andrew)
3. Checking CPU and memory usage for an IOC (Wang, Andrew)
4. Re: Checking CPU and memory usage for an IOC (Simon Rose)
Message: 1
Date: Mon, 12 Dec 2022 20:45:57 +0000
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: Phoebus Alarm Server on CentOS 9?
Message-ID:
<DM6PR09MB5607749F6E24E2C4DC56D20ACAE29 at DM6PR09MB5607.namprd09.prod.outlook.com>
Content-Type: text/plain; charset="iso-8859-1"
I'm trying to get the Phoebus alarm-server to run on CentOS 9 here, and it launches, connects to Kafka OK, but it cannot "see" the EPICS channel access PVs. From the command line before launching alarm-server, I can "caget" the variables, but in alarm-server
it shows "disconnected"
Java 13, CentOS 9 5.14.0-183.el9.x86_64
The alarm-server works fine on SL7 servers and can "see" EPICS IOCs
Ideas?
William Badgett
Accelerator Division Controls
Neutrino Division Operations
Fermi National Accelerator Lab
Kirk and Wilson Roads
BTE-214 Booster Tower East Room 214
Batavia, IL 60510 U.S.A.
badgett at fnal.gov
URL: <
https://urldefense.proofpoint.com/v2/url?u=http-3A__mailman.aps.anl.gov_pipermail_tech-2Dtalk_attachments_20221212_1bfe4994_attachment.html&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=3eGhPpS5OdvaS0XvqCBgfaeoUQq_mLMgiDk7pJ201Lg&e=
Message: 2
Date: Mon, 12 Dec 2022 22:11:28 +0000
To: Mark Rivers <rivers at cars.uchicago.edu>, EPICS tech-talk
Subject: Re: Ways to know if instrument connected via TCP/IP through
Message-ID:
<BY3PR09MB81945E11CD3D0BCAEAD923D282E29 at BY3PR09MB8194.namprd09.prod.outlook.com>
Content-Type: text/plain; charset="us-ascii"
Mark,
This is extremely helpful. I will let you know if I have follow up questions.
Andy
Sent: Thursday, December 8, 2022 6:51 PM
To: EPICS tech-talk <tech-talk at aps.anl.gov>; Wang, Andrew <wang126 at llnl.gov>
Subject: Re: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection
Hi Andy,
> I feel like there is a better way than me trying to use a calcout record and check if any record has its STAT field set to COMM. Like, is it possible to monitor for connection status without needing to process a record whose device type is StreamDevice and
check its STAT field?
Yes, there is a better way.
First, you probably want to use this line in your startup script:
asynSetOption("$(PORT)",0, "disconnectOnReadTimeout", "Y")
That will cause the port to disconnect if there is a timeout. If you don't do that then the asyn won't know that the port is disconnected for a very long time on Linux, it will just keep giving "temporarily unavailable" messages.
In your startup script load an asyn record that is connected to that asyn port. Here is an example:
dbLoadRecords("$(ASYN)/db/asynRecord.db", "P=IOC:, R=asyn1, PORT=ARIES1, ADDR=0, OMAX=256, IMAX=256")
You can monitor the IOC:asyn1.CNCT field, which will either be "Connect" or "Disconnect".
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Wang, Andrew via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, December 8, 2022 8:21 PM
Subject: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection
Hi all,
Basically, I was wondering if there is a better way to know if communication to an instrument has been lost. I understand that this can be done either by simplying looking at the IOC shell for disconnection errors or checking if the STAT field is set to COMM.
I was wondering if there is another method of determining if the instrument is still connected or not besides the two methods described above. Additionally, I would like to have a record called "is_instrument_connected", that holds a value like 1 to indicate
the instrument is connected and a 0 if it is not. I feel like there is a better way than me trying to use a calcout record and check if any record has its STAT field set to COMM. Like, is it possible to monitor for connection status without needing to process
a record whose device type is StreamDevice and check its STAT field?
Thank you,
Andy
URL: <
https://urldefense.proofpoint.com/v2/url?u=http-3A__mailman.aps.anl.gov_pipermail_tech-2Dtalk_attachments_20221212_b45bb99d_attachment.html&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=qHRQGiCsAbr5CzTlsinIOaUd77za3vna-MkxJba6PnQ&e=
Message: 3
Date: Mon, 12 Dec 2022 22:13:29 +0000
Subject: Checking CPU and memory usage for an IOC
Message-ID:
<BY3PR09MB819412B9EC493B3E541D5D3582E29 at BY3PR09MB8194.namprd09.prod.outlook.com>
All,
This is a very general question, but I was curious if people here have been able to monitor CPU and memory usage of a particular IOC as it ran. If so, what was the approach you took to do so?
Thank you,
Andy
URL: <
https://urldefense.proofpoint.com/v2/url?u=http-3A__mailman.aps.anl.gov_pipermail_tech-2Dtalk_attachments_20221212_5583a2f7_attachment.html&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=o2V2mQkuVwXZJ3yMdBcydk4wFK5Nbo8K5JwBxHDBO3c&e=
Message: 4
Date: Mon, 12 Dec 2022 22:34:06 +0000
To: "Wang, Andrew" <wang126 at llnl.gov>, EPICS tech-talk
Subject: Re: Checking CPU and memory usage for an IOC
Message-ID: <45E594FF-D6DE-4272-9D0A-7CF7431986E4 at ess.eu>
Content-Type: text/plain; charset="utf-8"
Hi Andy ?
There is the iocStats module that might do what you are looking for:
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_epics-2Dmodules_iocStats&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=MYLwjAZ7todFqhQxET171vSWJu04AIucD8Dxedy6Xkk&e=
In particular, there is a record that specifically monitors CPU usage:
https://urldefense.proofpoint.com/v2/url?u=https-3A__github.com_epics-2Dmodules_iocStats_blob_master_iocAdmin_Db_ioc.template-23L130&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=epdhYOowPFxhHltfuC37GNBGq3BdE2xZctk9ug2iPww&e=
(as well as one for memory usage).
Cheers,
Simon
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Wang, Andrew" <wang126 at llnl.gov>
Date: Monday, 12 December 2022 at 23:13
All,
Thank you,
Andy
URL: <
https://urldefense.proofpoint.com/v2/url?u=http-3A__mailman.aps.anl.gov_pipermail_tech-2Dtalk_attachments_20221212_16a75125_attachment.html&d=DwICAg&c=gRgGjJ3BkIsb5y6s49QqsA&r=rFOy-ydFEnpKcV3qYX1tt7JonnG1Pzrsmr398l7QSm4&m=uCbIidZWhQIOD-BoyeOvNjOU1mpW0410IHM8JGvBYDCKytPy0zF2Cpn7knZKU_zb&s=sp4klXWm9uVRgBpiCt_uDlrvYW-EkOfJxBivcgvfDfQ&e=
Subject: Digest Footer
Tech-talk mailing list Tech-talk at aps.anl.gov
End of Tech-talk Digest, Vol 16, Issue 712
