For MTCA specific configuration in mrfioc2, please take a look at the sample configuration here:
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/Db/evr-mtca-300.substitutions
in particular the substitutions for mrmevrout.db (from line 99 onwards). You see lines with FrontUnivOut[0,1], those should do the job for the Universal I/O slots in the front panel.
For the RTM outputs there is no example in the above file but I think you should be able to configure them using definitions like "RearUniv0" etc.
I am a little bit rusty on this so if there is somebody with recent practical experience, I would be happy if you could confirm that this is the case, or give the correct solution.
I hope this helps.
Best regards,
Timo
On 2023-01-26, 08:06, "Tech-talk on behalf of Jukka Pietarinen via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi Giampiero,
From the hardware point of view on the mTCA-EVR-300U the front panel
Universal I/Os are configured/mapped through registers at offset
0x440-0x447 (Front Panel Universal I/O Mapping Registers) and the RTM
Universal I/Os are mapped through registers at offset 0x480-0x493
(Transition Board Output Mapping Registers).
Unfortunately, I cannot help with configuring this through mrfioc2.
Jukka
On 1/25/23 4:53 PM, dipirro via Tech-talk wrote:
> Hi, I have an mrf system set up as follows:
> One mTCA-EVR-300 with 2 Universal I/O LVTTL Output UNIV-TTL and one
> mTCA.4 Rear Transition Module (mTCA-EVRTM-300) with 3 Universal I/O
> LVTTL Output UNIV
> I installed mrfioc2 but I don't know how to configure it to allow the
> use of Universal I/O
- Re: Problems using Universal I/O Han Lee via Tech-talk
- Problems using Universal I/O dipirro via Tech-talk
- Re: Problems using Universal I/O Jukka Pietarinen via Tech-talk
Re: abdf1 driver that logs with logMsg? - I know this is a real long shot Ralph Lange via Tech-talk
Re: Strange memory leak with ADAravis Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
