Hi Timo,
This file was developed by me and Javier, and I think ESS has the corresponding db or substitutions files locally. If so, could you, Jerzy or Javier, push ESS local files to the community repository?
Best, Han
On Thu, Jan 26, 2023 at 6:22 AM Timo Korhonen via Tech-talk < [email protected]> wrote: Hi,
For MTCA specific configuration in mrfioc2, please take a look at the sample configuration here:
https://github.com/epics-modules/mrfioc2/blob/master/evrMrmApp/Db/evr-mtca-300.substitutions
in particular the substitutions for mrmevrout.db (from line 99 onwards). You see lines with FrontUnivOut[0,1], those should do the job for the Universal I/O slots in the front panel.
For the RTM outputs there is no example in the above file but I think you should be able to configure them using definitions like "RearUniv0" etc.
I am a little bit rusty on this so if there is somebody with recent practical experience, I would be happy if you could confirm that this is the case, or give the correct solution.
I hope this helps.
Best regards,
Timo
On 2023-01-26, 08:06, "Tech-talk on behalf of Jukka Pietarinen via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi Giampiero,
From the hardware point of view on the mTCA-EVR-300U the front panel
Universal I/Os are configured/mapped through registers at offset
0x440-0x447 (Front Panel Universal I/O Mapping Registers) and the RTM
Universal I/Os are mapped through registers at offset 0x480-0x493
(Transition Board Output Mapping Registers).
Unfortunately, I cannot help with configuring this through mrfioc2.
Jukka
On 1/25/23 4:53 PM, dipirro via Tech-talk wrote:
> Hi, I have an mrf system set up as follows:
> One mTCA-EVR-300 with 2 Universal I/O LVTTL Output UNIV-TTL and one
> mTCA.4 Rear Transition Module (mTCA-EVRTM-300) with 3 Universal I/O
> LVTTL Output UNIV
> I installed mrfioc2 but I don't know how to configure it to allow the
> use of Universal I/O
Jeong Han Lee, Dr.rer.nat Staff Scientist and Engineer Lawrence Berkeley National Laboratory 1 Cyclotron Road Mailstop 46R0161 Berkeley, CA 94720, United States Tel :+1-510-486-6163
Cell:+1-510-384-3868
- Re: Problems using Universal I/O Han Lee via Tech-talk
- Re: Problems using Universal I/O Timo Korhonen via Tech-talk
- Problems using Universal I/O dipirro via Tech-talk
- Re: Problems using Universal I/O Jukka Pietarinen via Tech-talk
RE: Strange memory leak with ADAravis Mark Rivers via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
