1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: CSS / Phoebus on Windows 11
From: Stefen Paul via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Sat, 11 Feb 2023 20:00:30 +0530
Dear All,
Do CSS-4.5.9 or Phoebus work properly on WIndows 11  with JDK 17 installed ?
I am facing issues while running both.
When I try to run CSS-4.5.9, I get a long list of errors in log file which is copied below :
!SESSION 2023-02-11 19:56:13.861 -----------------------------------------------
eclipse.buildId=unknown
java.version=17.0.6
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Command-line arguments:  -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.equinox.ds 1 0 2023-02-11 19:56:14.432
!MESSAGE Could not bind a reference of component org.csstudio.diirt.util.RegisterDatasource. The reference is: Reference[name = DataSourceProvider, interface = org.diirt.datasource.DataSourceProvider, policy = dynamic, cardinality = 0..n, target = null, bind = registerDatasource, unbind = deregisterDatasource]
!ENTRY org.eclipse.equinox.ds 1 0 2023-02-11 19:56:14.444
!MESSAGE Could not bind a reference of component org.csstudio.diirt.util.RegisterFormulaFunctionSet. The reference is: Reference[name = FormulaFunctionSet, interface = org.diirt.datasource.formula.FormulaFunctionSet, policy = dynamic, cardinality = 0..n, target = null, bind = registerFormulaFunctionSet, unbind = deregisterFormulaFunctionSet]
!MESSAGE Could not bind a reference of component org.csstudio.diirt.util.RegisterService. The reference is: Reference[name = ServiceProvider, interface = org.diirt.service.ServiceProvider, policy = static, cardinality = 0..n, target = null, bind = registerService, unbind = null]
!ENTRY org.eclipse.osgi 4 0 2023-02-11 19:56:17.082
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:386)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultHeadlessContext(E4Application.java:490)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:504)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:203)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:632)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:336)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:148)
at org.csstudio.utility.product.Workbench.runWorkbench(Workbench.java:99)
at org.csstudio.startup.application.Application.startApplication(Application.java:265)
at org.csstudio.startup.application.Application.start(Application.java:119)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:388)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:243)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: java.lang.NoClassDefFoundError: javax/annotation/PostConstruct
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
... 25 more
Caused by: java.lang.ClassNotFoundException: javax.annotation.PostConstruct cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:520)
... 27 more
!ENTRY org.eclipse.e4.ui.workbench 4 0 2023-02-11 19:56:17.086
!MESSAGE FrameworkEvent ERROR
!STACK 0
java.lang.NoClassDefFoundError: javax/annotation/PreDestroy
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:154)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:78)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:111)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:74)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:176)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.dispose(EclipseContextOSGi.java:106)
at org.eclipse.e4.core.internal.contexts.osgi.EclipseContextOSGi.bundleChanged(EclipseContextOSGi.java:139)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:903)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:156)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.doStop(Module.java:634)
at org.eclipse.osgi.container.Module.stop(Module.java:498)
at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:202)
at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:165)
at java.base/java.lang.Thread.run(Thread.java:833)
Caused by: java.lang.ClassNotFoundException: javax.annotation.PreDestroy cannot be found by org.eclipse.e4.core.di_1.6.1.v20160712-0927
... 21 more
!ENTRY org.eclipse.core.resources 2 10035 2023-02-11 19:56:17.108
!MESSAGE The workspace will exit with unsaved changes in this session.
Looking forward to some help in this matter.
Stefen
Prev: Re: PVaccess | pva2pva/QSRV Resources Ignacio Arriagada via Tech-talk
Next: RE: linux kernel module for mrfioc2 on MTCA 문건영(선형가속기팀) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: mrfioc2 AC syncronization Michael Davidsaver via Tech-talk
Next: PilatusDetector-Requested threshold (0.00 eV) is out of range 鲍康文 via Tech-talk
