Dear Mark,
We use Pilatus2M Detector,it can be worked,but have a problem
2023/02/13 11:08:01.098 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Requested threshold (0.00 eV) is out of range.
this message is ...
i don't know What is problem...
the camserver is alive(it is OK in ping test and the medm can work)
epicsEnvSet("IOC","iocPilatus") epicsEnvSet("TOP","/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC") epicsEnvSet("ADPILATUS","/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/../..") epicsEnvSet("SUPPORT","/home/mx17b/epics/synApps/support") epicsEnvSet("ASYN","/home/mx17b/epics/synApps/support/asyn-R4-33") epicsEnvSet("AREA_DETECTOR","/home/mx17b/epics/synApps/support/areaDetector-R3-3-1") epicsEnvSet("ADSUPPORT","/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADSupport") epicsEnvSet("ADCORE","/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore") epicsEnvSet("AUTOSAVE","/home/mx17b/epics/synApps/support/autosave-R5-9") epicsEnvSet("BUSY","/home/mx17b/epics/synApps/support/busy-R1-7") epicsEnvSet("CALC","/home/mx17b/epics/synApps/support/calc-R3-7-1") epicsEnvSet("SNCSEQ","/home/mx17b/epics/synApps/support/seq-2-2-5") epicsEnvSet("SSCAN","/home/mx17b/epics/synApps/support/sscan-R2-11-1") epicsEnvSet("DEVIOCSTATS","/home/mx17b/epics/synApps/support/iocStats-3-1-15") epicsEnvSet("EPICS_BASE","/home/mx17b/epics/base") errlogInit(20000) dbLoadDatabase("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/dbd/pilatusDetectorApp.dbd") medmInit: Unable to load font widgetDM_4 Trying default (fixed) instead medmInit: Unable to load font widgetDM_6 Trying default (fixed) instead medmInit: Unable to load font widgetDM_8 Trying default (fixed) instead medmInit: Unable to load font widgetDM_10 Trying default (fixed) instead medmInit: Unable to load font widgetDM_12 Trying default (fixed) instead medmInit: Unable to load font widgetDM_14 Trying default (fixed) instead medmInit: Unable to load font widgetDM_16 Trying default (fixed) instead medmInit: Unable to load font widgetDM_18 Trying default (fixed) instead medmInit: Unable to load font widgetDM_20 Trying default (fixed) instead medmInit: Unable to load font widgetDM_22 Trying default (fixed) instead medmInit: Unable to load font widgetDM_24 Trying default (fixed) instead medmInit: Unable to load font widgetDM_30 Trying default (fixed) instead medmInit: Unable to load font widgetDM_36 Trying default (fixed) instead medmInit: Unable to load font widgetDM_40 Trying default (fixed) instead medmInit: Unable to load font widgetDM_48 Trying default (fixed) instead medmInit: Unable to load font widgetDM_60 Trying default (fixed) instead MEDM Version 3.1.11: Loading aliased fonts................. pilatusDetectorApp_registerRecordDeviceDriver(pdbbase) # Prefix for all records epicsEnvSet("PREFIX", "BL17B:") # The port name for the detector epicsEnvSet("PORT", "PIL") # The queue size for all plugins epicsEnvSet("QSIZE", "20") # The maximim image width; used for row profiles in the NDPluginStats plugin epicsEnvSet("XSIZE", "1475") # The maximim image height; used for column profiles in the NDPluginStats plugin epicsEnvSet("YSIZE", "1679") # The maximum number of time seried points in the NDPluginStats plugin epicsEnvSet("NCHANS", "2048") # The maximum number of frames buffered in the NDPluginCircularBuff plugin epicsEnvSet("CBUFFS", "500") # The search path for database files epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db") epicsEnvSet("EPICS_CAS_SERVER_PORT", "5078") ### # Create the asyn port to talk to the Pilatus on port 41234. drvAsynIPPortConfigure("camserver","10.30.63.181:41234") # Uncomment the following to enable asynTrace on the camserver port #asynSetTraceIOMask("camserver",0,2) #asynSetTraceMask("camserver",0,9) # Set the input and output terminators. asynOctetSetInputEos("camserver", 0, "\x18") asynOctetSetOutputEos("camserver", 0, "\n") pilatusDetectorConfig("PIL", "camserver", 1475, 1679, 0, 0) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/../../db/pilatus.template","P=BL17B:,R=cam1:,PORT=PIL,ADDR=0,TIMEOUT=1,CAMSERVER_PORT=camserver") # Create a standard arrays plugin NDStdArraysConfigure("Image1", 5, 0, "PIL", 0, 0) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDStdArrays.template", "P=BL17B:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,TYPE=Int32,FTVL=LONG,NELEMENTS=94965") # Load all other plugins using commonPlugins.cmd < /home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/iocBoot/commonPlugins.cmd # This is an example file for creating plugins # It uses the following environment variable macros # Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being # use the autosave value will replace the value passed to this file. # $(PREFIX) Prefix for all records # $(PORT) The port name for the detector. In autosave. # $(QSIZE) The queue size for all plugins. In autosave. # $(XSIZE) The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT # profiles in NDPluginFFT. # $(YSIZE) The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin # $(NCHANS) The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins # $(CBUFFS) The maximum number of frames buffered in the NDPluginCircularBuff plugin # $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5. # Create a netCDF file saving plugin NDFileNetCDFConfigure("FileNetCDF1", 20, 0, "PIL", 0) dbLoadRecords("NDFileNetCDF.template","P=BL17B:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a TIFF file saving plugin NDFileTIFFConfigure("FileTIFF1", 20, 0, "PIL", 0) dbLoadRecords("NDFileTIFF.template", "P=BL17B:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a JPEG file saving plugin NDFileJPEGConfigure("FileJPEG1", 20, 0, "PIL", 0) dbLoadRecords("NDFileJPEG.template", "P=BL17B:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a NeXus file saving plugin NDFileNexusConfigure("FileNexus1", 20, 0, "PIL", 0) dbLoadRecords("NDFileNexus.template", "P=BL17B:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create an HDF5 file saving plugin NDFileHDF5Configure("FileHDF1", 20, 0, "PIL", 0) dbLoadRecords("NDFileHDF5.template", "P=BL17B:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a Magick file saving plugin #NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0) #dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Create 4 ROI plugins NDROIConfigure("ROI1", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=BL17B:,R=ROI1:, PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") NDROIConfigure("ROI2", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=BL17B:,R=ROI2:, PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") NDROIConfigure("ROI3", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=BL17B:,R=ROI3:, PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") NDROIConfigure("ROI4", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDROI.template", "P=BL17B:,R=ROI4:, PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create 8 ROIStat plugins NDROIStatConfigure("ROISTAT1", 20, 0, "PIL", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDROIStat.template", "P=BL17B:,R=ROIStat1: ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDROIStatN.template", "P=BL17B:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048") # Create a processing plugin NDProcessConfigure("PROC1", 20, 0, "PIL", 0, 0, 0) dbLoadRecords("NDProcess.template", "P=BL17B:,R=Proc1:, PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a TIFF file plugin to read dark and flatfield images into the processing plugin NDFileTIFFConfigure("PROC1TIFF", 20, 0, "PIL", 0) dbLoadRecords("NDFileTIFF.template", "P=BL17B:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a scatter plugin NDScatterConfigure("SCATTER1", 20, 0, "PIL", 0, 0, 0) dbLoadRecords("NDScatter.template", "P=BL17B:,R=Scatter1:, PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a gather plugin with 8 ports NDGatherConfigure("GATHER1", 20, 0, 8, 0, 0) dbLoadRecords("NDGather.template", "P=BL17B:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDGatherN.template", "P=BL17B:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=PIL") # Create 5 statistics plugins NDStatsConfigure("STATS1", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=BL17B:,R=Stats1:, PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1475,YSIZE=1679,NCHANS=2048,NDARRAY_PORT=PIL") NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDTimeSeries.template", "P=BL17B:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS2", 20, 0, "ROI1", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=BL17B:,R=Stats2:, PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1475,YSIZE=1679,NCHANS=2048,NDARRAY_PORT=PIL") NDTimeSeriesConfigure("STATS2_TS", 20, 0, "STATS2", 1, 23) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDTimeSeries.template", "P=BL17B:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS3", 20, 0, "ROI2", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=BL17B:,R=Stats3:, PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1475,YSIZE=1679,NCHANS=2048,NDARRAY_PORT=PIL") NDTimeSeriesConfigure("STATS3_TS", 20, 0, "STATS3", 1, 23) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDTimeSeries.template", "P=BL17B:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS4", 20, 0, "ROI3", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=BL17B:,R=Stats4:, PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1475,YSIZE=1679,NCHANS=2048,NDARRAY_PORT=PIL") NDTimeSeriesConfigure("STATS4_TS", 20, 0, "STATS4", 1, 23) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDTimeSeries.template", "P=BL17B:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") NDStatsConfigure("STATS5", 20, 0, "ROI4", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDStats.template", "P=BL17B:,R=Stats5:, PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1475,YSIZE=1679,NCHANS=2048,NDARRAY_PORT=PIL") NDTimeSeriesConfigure("STATS5_TS", 20, 0, "STATS5", 1, 23) dbLoadRecords("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/db/NDTimeSeries.template", "P=BL17B:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1") # Create a transform plugin NDTransformConfigure("TRANS1", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDTransform.template", "P=BL17B:,R=Trans1:, PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create an overlay plugin with 8 overlays NDOverlayConfigure("OVER1", 20, 0, "PIL", 0, 8, 0, 0, 0, 0, 5) dbLoadRecords("NDOverlay.template", "P=BL17B:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:1:,NAME=ROI1, SHAPE=1,O=Over1:,XPOS=BL17B:ROI1:MinX_RBV,YPOS=BL17B:ROI1:MinY_RBV,XSIZE=BL17B:ROI1:SizeX_RBV,YSIZE=BL17B:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:2:,NAME=ROI2, SHAPE=1,O=Over1:,XPOS=BL17B:ROI2:MinX_RBV,YPOS=BL17B:ROI2:MinY_RBV,XSIZE=BL17B:ROI2:SizeX_RBV,YSIZE=BL17B:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:3:,NAME=ROI3, SHAPE=1,O=Over1:,XPOS=BL17B:ROI3:MinX_RBV,YPOS=BL17B:ROI3:MinY_RBV,XSIZE=BL17B:ROI3:SizeX_RBV,YSIZE=BL17B:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:4:,NAME=ROI4, SHAPE=1,O=Over1:,XPOS=BL17B:ROI4:MinX_RBV,YPOS=BL17B:ROI4:MinY_RBV,XSIZE=BL17B:ROI4:SizeX_RBV,YSIZE=BL17B:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=4,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=5,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:7:,NAME=Box1, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=6,TIMEOUT=1") dbLoadRecords("NDOverlayN.template","P=BL17B:,R=Over1:8:,NAME=Box2, SHAPE=1,O=Over1:,XPOS=junk, YPOS=junk, XSIZE=junk, YSIZE=junk, PORT=OVER1,ADDR=7,TIMEOUT=1") # Create 2 color conversion plugins NDColorConvertConfigure("CC1", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=BL17B:,R=CC1:, PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") NDColorConvertConfigure("CC2", 20, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDColorConvert.template", "P=BL17B:,R=CC2:, PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create a circular buffer plugin NDCircularBuffConfigure("CB1", 20, 0, "PIL", 0, 500, 0) dbLoadRecords("NDCircularBuff.template", "P=BL17B:,R=CB1:, PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PIL") # Create an NDAttribute plugin with 8 attributes NDAttrConfigure("ATTR1", 20, 0, "PIL", 0, 8, 0, 0, 0) dbLoadRecords("NDAttribute.template", "P=BL17B:,R=Attr1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=PIL") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:1:, PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:2:, PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:3:, PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:4:, PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:5:, PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:6:, PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:7:, PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048") dbLoadRecords("NDAttributeN.template", "P=BL17B:,R=Attr1:8:, PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048") # Create an FFT plugin NDFFTConfigure("FFT1", 3, 0, "PIL", 0, 0, 0, 0, 0, 5) dbLoadRecords("NDFFT.template", "P=BL17B:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=PIL, NAME=FFT1, NCHANS=1475") set_requestfile_path("./") set_requestfile_path("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/ADApp/Db") set_requestfile_path("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADCore/iocBoot") set_savefile_path("./autosave") set_pass0_restoreFile("auto_settings.sav") set_pass1_restoreFile("auto_settings.sav") save_restoreSet_status_prefix("BL17B:") dbLoadRecords("/home/mx17b/epics/synApps/support/autosave-R5-9/asApp/Db/save_restoreStatus.db", "P=BL17B:") # Optional: load NDPluginPva plugin #NDPvaConfigure("PVA1", $(QSIZE), 0, "$(PORT)", 0, $(PREFIX)Pva1:Image, 0, 0, 0) #dbLoadRecords("NDPva.template", "P=$(PREFIX),R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") # Must start PVA server if this is enabled #startPVAServer # Optional: load NDPluginEdge plugin #NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0) #dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template", "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)") #set_requestfile_path("$(ADPLUGINEDGE)/edgeApp/Db") # Optional: load scan records #dbLoadRecords("$(SSCAN)/sscanApp/Db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10") #set_requestfile_path("$(SSCAN)/sscanApp/Db") # Optional: load sseq record for acquisition sequence #dbLoadRecords("$(CALC)/calcApp/Db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence") #set_requestfile_path("$(CALC)/calcApp/Db") # Optional: load devIocStats records (requires DEVIOCSTATS module) #dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)") # Optional: load alive record (requires ALIVE module) #dbLoadRecords("$(ALIVE)/aliveApp/Db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254") set_requestfile_path("/home/mx17b/epics/synApps/support/areaDetector-R3-3-1/ADPilatus/iocs/pilatusIOC/../../pilatusApp/Db") # Uncomment to enable asynTrace on the driver port #asynSetTraceMask("$(PORT)",0,255) iocInit() Starting iocInit ############################################################################ ## EPICS R3.15.9 ## EPICS Base built Jan 27 2022 ############################################################################ reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** reboot_restore: done with file 'auto_settings.sav' reboot_restore: entry for file 'auto_settings.sav' reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** reboot_restore: done with file 'auto_settings.sav' iocRun: All initialization complete # save things every thirty seconds create_monitor_set("auto_settings.req", 30,"P=BL17B:") save_restore:readReqFile: unable to open file commonPlugin_settings.req. Exiting. 2023/02/13 11:07:31.003 pilatusDetector::readBadPixelFile, cannot open file /home/det/p2_det/config/bad_pixel.txt 2023/02/13 11:07:31.042 pilatusDetector:readCamserver unexpected response from camserver, no OK, response=15 ERR Requested threshold (0.00 eV) is out of range
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
