Hi folks
I am trying hard to set up a Raspberry running an EPICS IOC for a Delta
VFD motor driver / frequency inverter. The device is controlled via
modbus, using a large set of individual 16bit integer read/write
registers for configuration, and few more registers for control.
At the moment it is configured to talk Modbus ASCII via RS485, and with
a simple Python program using minimalmodbus-lib i can talk to the
controller.
Now i started with a fresh EPICS 3.15.7 base, (in ~/EPICS/base) and
installed ASYN-R4-43 (~/EPICS/modules/asyn-R4-43) and modbus
(~/EPICS/modules/modbus_R3-2).
I initiated a new application ~/EPICS/projects/FUcontrol,
ran "makeBaseApp.pl -t example FUcontrol", "makeBaseApp.pl -i -t example
FUcontrol" - and thats basically it.
And now i am stuck how to include modbus (includes / libs / dbd files)
into my exampleApp.
I kind of managed to include ASYN already by adding
ASYN=... to the RELEASE file
and to the Makefile:
FUcontrol_LIBS += asyn
In my ioc startup st.cmd i can run the commands
drvAsynSerialPortConfigure("RS485", "/dev/ttyUSB0", 0, 0, 0)
to configure the interface.
But if i add
modbusInterposeConfig("RS485",2,1000,0)
i get an error on startup claiming that modnusinterposeconfig can not be
found.
So:
Is there any simple step-by-step instructions how to add modbus to an
existing ioc application ?
I could not find anything "simple" in the documentation. I saw the
examples which come with modbus, but all these already look quite
complicated to me...
Or any good advise on how to continue from here ?
Thanks for any help !
Christian
- Re: Help getting modbus module started Pierrick M Hanlet via Tech-talk
Re: Multiple sequencer instances undesirably sharing information Jure Varlec via Tech-talk
<2023>
2025
2026
RE: Archiver appliance sampling buffer overflows after migration from Version 2018 to Version 1.1.0 Wang, Lin via Tech-talk
<2023>
2025
2026
