1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: RE: Cpp code not recognizing asyn parameter
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "Marco A. Barra Montevechi Filho" <marco.filho at lnls.br>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Cc: SWC <swc at lnls.br>
Date: Wed, 15 Feb 2023 17:15:07 +0000
Hi Marco,
Did you set the mask for the asynInt32 interface in the constructor for you driver?
Please send the complete output when the IOC boots with your driver.  There may be an error message there.
Also send the output of this command at the IOC prompt:
asynReport 10
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Marco A. Barra Montevechi Filho via Tech-talk
Sent: Wednesday, February 15, 2023 9:39 AM
To: tech-talk at aps.anl.gov
Subject: Cpp code not recognizing asyn parameter
Hello all. Im trying to use the asyn module to associate the value of a PV to the value of a variable inside my cpp code.
The PV is defined as:
record(mbbo, "$(P)$(BE)DynamicRange"){
    field(DTYP, "asynInt32")
    field(ONVL, "1")
    field(ONST, "Full Dynamic Range")
    field(ZRVL, "0")
    field(ZRST, "Default")
    field(OUT,  "@asyn($(PORT),$(ADDR=0),$(TIMEOUT=1))DYNAMIC_RANGE")
In my header file i have:
#define DynamicRangeString            "DYNAMIC_RANGE"
int DynamicRangeString_;
and inside my .cpp:
createParam(DynamicRangeString,             asynParamInt32,   &DynamicRangeString_);
asynStatus Mobipix::writeInt32(asynUser *pasynUser, epicsInt32 value)
printf("test");
When i dbpf into other asyn mbbo records that come from ADBase.template, such as "$(P)$(R)FrameType", the ioc shell prints the test message. When i dbpf into my DynamicRange PV nothing happens.
What am i missing?
Thanks for the help,
Marco
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Re: Cpp code not recognizing asyn parameter Marco A. Barra Montevechi Filho via Tech-talk
Prev: Cpp code not recognizing asyn parameter Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: Cpp code not recognizing asyn parameter Marco A. Barra Montevechi Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 15 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
