Is that why there was no error message?
asynReport 10 returns a long output which i managed to reduce a little by ommiting load of ADBase common_Plugins:
epics> asynReport 10
SIM1 multiDevice:Yes canBlock:No autoConnect:Yes
enabled:Yes connected:Yes numberConnects 1
nDevices 3 nQueued 0 blocked:No
asynManagerLock:No synchronousLock:No
exceptionActive:No exceptionUsers 0 exceptionNotifys 0
traceMask:0x21 traceIOMask:0x1 traceInfoMask:0x1
interposeInterfaceList
asynOctet pinterface 0x117b720 drvPvt 0x11e6090
interfaceList
asynCommon pinterface 0x117ba40 drvPvt 0x11e26b0
asynDrvUser pinterface 0x117ba58 drvPvt 0x11e26b0
asynOctet pinterface 0x117bb18 drvPvt 0x11e26b0
asynInt32 pinterface 0x117ba70 drvPvt 0x11e26b0
asynFloat64 pinterface 0x117baf8 drvPvt 0x11e26b0
asynInt32Array pinterface 0x117bba0 drvPvt 0x11e26b0
asynGenericPointer pinterface 0x117bc20 drvPvt 0x11e26b0
addr 0 autoConnect Yes enabled Yes connected Yes exceptionActive No
exceptionActive No exceptionUsers 1 exceptionNotifys 0
blocked No
addr 1 autoConnect Yes enabled Yes connected No exceptionActive No
exceptionActive No exceptionUsers 0 exceptionNotifys 0
blocked No
addr 2 autoConnect Yes enabled Yes connected No exceptionActive No
blocked No
traceMask:0x1 traceIOMask:0x0 traceInfoMask:0x1
Simulation detector SIM1
NX, NY: 512 512
Data type: 3
Port: SIM1
Timestamp: <undefined>
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Number of parameters is: 102
Parameter 0 type=string, name=PORT_NAME_SELF, value=SIM1, status=0
Parameter 1 type=string, name=ADCORE_VERSION, value=3.11.0, status=0
Parameter 2 type=string, name=DRIVER_VERSION, value=1.0.0, status=0
Parameter 3 type=string, name=MANUFACTURER, value=Mobipix Detector, status=0
Parameter 4 type=string, name=MODEL, value=Mobipix 1, status=0
Parameter 5 type=string, name=SERIAL_NUMBER, value=No serial number, status=0
Parameter 6 type=string, name=SDK_VERSION, value=1.0.0, status=0
Parameter 7 type=string, name=FIRMWARE_VERSION, value=LNLS/CNPEM, status=0
Parameter 8 type=asynInt32, name=ACQUIRE, value=0, status=0
Parameter 9 type=asynInt32, name=ACQUIRE_BUSY, value=0, status=0
Parameter 10 type=asynInt32, name=WAIT_FOR_PLUGINS, value=0, status=0
Parameter 11 type=asynInt32, name=ARRAY_SIZE_X, value=512, status=0
Parameter 12 type=asynInt32, name=ARRAY_SIZE_Y, value=512, status=0
Parameter 13 type=asynInt32, name=ARRAY_SIZE_Z, value=0, status=0
Parameter 14 type=asynInt32, name=ARRAY_SIZE, value=0, status=0
Parameter 15 type=asynInt32, name=ARRAY_NDIMENSIONS, value=0, status=0
Parameter 16 type=asynInt32, name=ARRAY_DIMENSIONS, value is undefined
Parameter 17 type=asynInt32, name=DATA_TYPE, value=3, status=0
Parameter 18 type=asynInt32, name=COLOR_MODE, value=0, status=0
Parameter 19 type=asynInt32, name=UNIQUE_ID, value=0, status=0
Parameter 20 type=asynFloat64, name=TIME_STAMP, value=0, status=0
Parameter 21 type=asynInt32, name=EPICS_TS_SEC, value=0, status=0
Parameter 22 type=asynInt32, name=EPICS_TS_NSEC, value=0, status=0
Parameter 23 type=asynInt32, name=BAYER_PATTERN, value=0, status=0
Parameter 24 type=string, name=CODEC, value is undefined
Parameter 25 type=asynInt32, name=COMPRESSED_SIZE, value is undefined
Parameter 26 type=asynInt32, name=ARRAY_COUNTER, value=0, status=0
Parameter 27 type=string, name=FILE_PATH, value=, status=0
Parameter 28 type=asynInt32, name=FILE_PATH_EXISTS, value is undefined
Parameter 29 type=string, name=FILE_NAME, value=, status=0
Parameter 30 type=asynInt32, name=FILE_NUMBER, value=0, status=0
Parameter 31 type=string, name=FILE_TEMPLATE, value=%s%s_%3.3d.dat, status=0
Parameter 32 type=asynInt32, name=AUTO_INCREMENT, value=0, status=0
Parameter 33 type=string, name=FULL_FILE_NAME, value is undefined
Parameter 34 type=asynInt32, name=FILE_FORMAT, value is undefined
Parameter 35 type=asynInt32, name=AUTO_SAVE, value is undefined
Parameter 36 type=asynInt32, name=WRITE_FILE, value=0, status=0
Parameter 37 type=asynInt32, name=READ_FILE, value=0, status=0
Parameter 38 type=asynInt32, name=WRITE_MODE, value is undefined
Parameter 39 type=asynInt32, name=WRITE_STATUS, value=0, status=0
Parameter 40 type=string, name=WRITE_MESSAGE, value=, status=0
Parameter 41 type=asynInt32, name=NUM_CAPTURE, value is undefined
Parameter 42 type=asynInt32, name=NUM_CAPTURED, value=0, status=0
Parameter 43 type=asynInt32, name=CAPTURE, value=0, status=0
Parameter 44 type=asynInt32, name=DELETE_DRIVER_FILE, value is undefined
Parameter 45 type=asynInt32, name=FILE_LAZY_OPEN, value is undefined
Parameter 46 type=asynInt32, name=CREATE_DIR, value=0, status=0
Parameter 47 type=string, name=FILE_TEMP_SUFFIX, value=, status=0
Parameter 48 type=string, name=ND_ATTRIBUTES_FILE, value=, status=0
Parameter 49 type=asynInt32, name=ND_ATTRIBUTES_STATUS, value=1, status=0
Parameter 50 type=string, name=ND_ATTRIBUTES_MACROS, value=, status=0
Parameter 51 is undefined, name=ARRAY_DATA
Parameter 52 type=asynInt32, name=ARRAY_CALLBACKS, value=1, status=0
Parameter 53 type=asynInt32, name=POOL_MAX_BUFFERS, value is undefined
Parameter 54 type=asynInt32, name=POOL_ALLOC_BUFFERS, value=0, status=0
Parameter 55 type=asynInt32, name=POOL_FREE_BUFFERS, value=0, status=0
Parameter 56 type=asynFloat64, name=POOL_MAX_MEMORY, value=0, status=0
Parameter 57 type=asynFloat64, name=POOL_USED_MEMORY, value=0, status=0
Parameter 58 type=asynInt32, name=POOL_EMPTY_FREELIST, value is undefined
Parameter 59 type=asynInt32, name=NUM_QUEUED_ARRAYS, value=0, status=0
Parameter 60 type=asynFloat64, name=GAIN, value=1, status=0
Parameter 61 type=asynInt32, name=BIN_X, value=1, status=0
Parameter 62 type=asynInt32, name=BIN_Y, value=1, status=0
Parameter 63 type=asynInt32, name=MIN_X, value=0, status=0
Parameter 64 type=asynInt32, name=MIN_Y, value=0, status=0
Parameter 65 type=asynInt32, name=SIZE_X, value=512, status=0
Parameter 66 type=asynInt32, name=SIZE_Y, value=512, status=0
Parameter 67 type=asynInt32, name=MAX_SIZE_X, value=512, status=0
Parameter 68 type=asynInt32, name=MAX_SIZE_Y, value=512, status=0
Parameter 69 type=asynInt32, name=REVERSE_X, value=0, status=0
Parameter 70 type=asynInt32, name=REVERSE_Y, value=0, status=0
Parameter 71 type=asynInt32, name=FRAME_TYPE, value=0, status=0
Parameter 72 type=asynInt32, name=IMAGE_MODE, value=2, status=0
Parameter 73 type=asynInt32, name=NEXPOSURES, value=1, status=0
Parameter 74 type=asynInt32, name=NEXPOSURES_COUNTER, value=0, status=0
Parameter 75 type=asynInt32, name=NIMAGES, value=1, status=0
Parameter 76 type=asynInt32, name=NIMAGES_COUNTER, value=0, status=0
Parameter 77 type=asynFloat64, name=ACQ_TIME, value=0.001, status=0
Parameter 78 type=asynFloat64, name=ACQ_PERIOD, value=0.005, status=0
Parameter 79 type=asynFloat64, name=TIME_REMAINING, value=0, status=0
Parameter 80 type=asynInt32, name=STATUS, value=0, status=0
Parameter 81 type=asynInt32, name=TRIGGER_MODE, value=0, status=0
Parameter 82 type=asynInt32, name=SHUTTER_CONTROL, value=0, status=0
Parameter 83 type=asynInt32, name=SHUTTER_CONTROL_EPICS, value is undefined
Parameter 84 type=asynInt32, name=SHUTTER_STATUS, value=0, status=0
Parameter 85 type=asynInt32, name=SHUTTER_MODE, value=0, status=0
Parameter 86 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value=0, status=0
Parameter 87 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value=0, status=0
Parameter 88 type=asynFloat64, name=TEMPERATURE, value=25, status=0
Parameter 89 type=asynFloat64, name=TEMPERATURE_ACTUAL, value is undefined
Parameter 90 type=asynInt32, name=READ_STATUS, value is undefined
Parameter 91 type=string, name=STATUS_MESSAGE, value=, status=0
Parameter 92 type=string, name=STRING_TO_SERVER, value=, status=0
Parameter 93 type=string, name=STRING_FROM_SERVER, value=, status=0
Parameter 94 type=asynInt32, name=MOBI_VITIMEOUT, value=1000, status=0
Parameter 95 type=asynInt32, name=MOBI_VIDEO0_N, value is undefined
Parameter 96 type=asynInt32, name=MOBI_VIDEO1_N, value is undefined
Parameter 97 type=asynInt32, name=MOBI_VIDEO0_ERRORS, value is undefined
Parameter 98 type=asynInt32, name=MOBI_VIDEO1_ERRORS, value is undefined
Parameter 99 type=asynInt32, name=MOBI_SAVE_FRAME_WITH_ERROR, value=0, status=0
Parameter 100 type=asynInt32, name=MOBI_USE_TRANSOFORM, value=1, status=0
Parameter 101 type=asynInt32, name=DYNAMIC_RANGE, value=0, status=0
Parameter list 1
Parameter 0 type=string, name=PORT_NAME_SELF, value is undefined
Parameter 1 type=string, name=ADCORE_VERSION, value is undefined
Parameter 2 type=string, name=DRIVER_VERSION, value is undefined
Parameter 3 type=string, name=MANUFACTURER, value is undefined
Parameter 4 type=string, name=MODEL, value is undefined
Parameter 5 type=string, name=SERIAL_NUMBER, value is undefined
Parameter 6 type=string, name=SDK_VERSION, value is undefined
Parameter 7 type=string, name=FIRMWARE_VERSION, value is undefined
Parameter 8 type=asynInt32, name=ACQUIRE, value is undefined
Parameter 9 type=asynInt32, name=ACQUIRE_BUSY, value is undefined
Parameter 10 type=asynInt32, name=WAIT_FOR_PLUGINS, value is undefined
Parameter 11 type=asynInt32, name=ARRAY_SIZE_X, value is undefined
Parameter 12 type=asynInt32, name=ARRAY_SIZE_Y, value is undefined
Parameter 13 type=asynInt32, name=ARRAY_SIZE_Z, value is undefined
Parameter 14 type=asynInt32, name=ARRAY_SIZE, value is undefined
Parameter 15 type=asynInt32, name=ARRAY_NDIMENSIONS, value is undefined
Parameter 17 type=asynInt32, name=DATA_TYPE, value is undefined
Parameter 18 type=asynInt32, name=COLOR_MODE, value is undefined
Parameter 19 type=asynInt32, name=UNIQUE_ID, value is undefined
Parameter 20 type=asynFloat64, name=TIME_STAMP, value is undefined
Parameter 21 type=asynInt32, name=EPICS_TS_SEC, value is undefined
Parameter 22 type=asynInt32, name=EPICS_TS_NSEC, value is undefined
Parameter 23 type=asynInt32, name=BAYER_PATTERN, value is undefined
Parameter 26 type=asynInt32, name=ARRAY_COUNTER, value is undefined
Parameter 27 type=string, name=FILE_PATH, value is undefined
Parameter 29 type=string, name=FILE_NAME, value is undefined
Parameter 30 type=asynInt32, name=FILE_NUMBER, value is undefined
Parameter 31 type=string, name=FILE_TEMPLATE, value is undefined
Parameter 32 type=asynInt32, name=AUTO_INCREMENT, value is undefined
Parameter 36 type=asynInt32, name=WRITE_FILE, value is undefined
Parameter 37 type=asynInt32, name=READ_FILE, value is undefined
Parameter 39 type=asynInt32, name=WRITE_STATUS, value is undefined
Parameter 40 type=string, name=WRITE_MESSAGE, value is undefined
Parameter 42 type=asynInt32, name=NUM_CAPTURED, value is undefined
Parameter 43 type=asynInt32, name=CAPTURE, value is undefined
Parameter 46 type=asynInt32, name=CREATE_DIR, value is undefined
Parameter 47 type=string, name=FILE_TEMP_SUFFIX, value is undefined
Parameter 48 type=string, name=ND_ATTRIBUTES_FILE, value is undefined
Parameter 49 type=asynInt32, name=ND_ATTRIBUTES_STATUS, value is undefined
Parameter 50 type=string, name=ND_ATTRIBUTES_MACROS, value is undefined
Parameter 52 type=asynInt32, name=ARRAY_CALLBACKS, value is undefined
Parameter 54 type=asynInt32, name=POOL_ALLOC_BUFFERS, value is undefined
Parameter 55 type=asynInt32, name=POOL_FREE_BUFFERS, value is undefined
Parameter 56 type=asynFloat64, name=POOL_MAX_MEMORY, value is undefined
Parameter 57 type=asynFloat64, name=POOL_USED_MEMORY, value is undefined
Parameter 59 type=asynInt32, name=NUM_QUEUED_ARRAYS, value is undefined
Parameter 60 type=asynFloat64, name=GAIN, value is undefined
Parameter 61 type=asynInt32, name=BIN_X, value is undefined
Parameter 62 type=asynInt32, name=BIN_Y, value is undefined
Parameter 63 type=asynInt32, name=MIN_X, value is undefined
Parameter 64 type=asynInt32, name=MIN_Y, value is undefined
Parameter 65 type=asynInt32, name=SIZE_X, value is undefined
Parameter 66 type=asynInt32, name=SIZE_Y, value is undefined
Parameter 67 type=asynInt32, name=MAX_SIZE_X, value is undefined
Parameter 68 type=asynInt32, name=MAX_SIZE_Y, value is undefined
Parameter 69 type=asynInt32, name=REVERSE_X, value is undefined
Parameter 70 type=asynInt32, name=REVERSE_Y, value is undefined
Parameter 71 type=asynInt32, name=FRAME_TYPE, value is undefined
Parameter 72 type=asynInt32, name=IMAGE_MODE, value is undefined
Parameter 73 type=asynInt32, name=NEXPOSURES, value is undefined
Parameter 74 type=asynInt32, name=NEXPOSURES_COUNTER, value is undefined
Parameter 75 type=asynInt32, name=NIMAGES, value is undefined
Parameter 76 type=asynInt32, name=NIMAGES_COUNTER, value is undefined
Parameter 77 type=asynFloat64, name=ACQ_TIME, value is undefined
Parameter 78 type=asynFloat64, name=ACQ_PERIOD, value is undefined
Parameter 79 type=asynFloat64, name=TIME_REMAINING, value is undefined
Parameter 80 type=asynInt32, name=STATUS, value is undefined
Parameter 81 type=asynInt32, name=TRIGGER_MODE, value is undefined
Parameter 82 type=asynInt32, name=SHUTTER_CONTROL, value is undefined
Parameter 84 type=asynInt32, name=SHUTTER_STATUS, value is undefined
Parameter 85 type=asynInt32, name=SHUTTER_MODE, value is undefined
Parameter 86 type=asynFloat64, name=SHUTTER_OPEN_DELAY, value is undefined
Parameter 87 type=asynFloat64, name=SHUTTER_CLOSE_DELAY, value is undefined
Parameter 88 type=asynFloat64, name=TEMPERATURE, value is undefined
Parameter 91 type=string, name=STATUS_MESSAGE, value is undefined
Parameter 92 type=string, name=STRING_TO_SERVER, value is undefined
Parameter 93 type=string, name=STRING_FROM_SERVER, value is undefined
Parameter 94 type=asynInt32, name=MOBI_VITIMEOUT, value is undefined
Parameter 99 type=asynInt32, name=MOBI_SAVE_FRAME_WITH_ERROR, value is undefined
Parameter 100 type=asynInt32, name=MOBI_USE_TRANSOFORM, value is undefined
Parameter 101 type=asynInt32, name=DYNAMIC_RANGE, value is undefined
Parameter list 2
int32 callback client address=0x5d3780, addr=0, reason=8, userPvt=0x167aa10
int32 callback client address=0x5d2d00, addr=0, reason=8, userPvt=0x152b440
int32 callback client address=0x5d2d00, addr=0, reason=9, userPvt=0x152bd50
int32 callback client address=0x5d2d00, addr=0, reason=52, userPvt=0x152c660
int32 callback client address=0x5d2d00, addr=0, reason=69, userPvt=0x152cf70
int32 callback client address=0x5d2d00, addr=0, reason=70, userPvt=0x152d880
int32 callback client address=0x5d2d00, addr=0, reason=82, userPvt=0x152eca0
int32 callback client address=0x5d2d00, addr=0, reason=84, userPvt=0x152f5b0
int32 callback client address=0x5d2d00, addr=0, reason=83, userPvt=0x152fec0
int32 callback client address=0x5d2d00, addr=0, reason=15, userPvt=0x1539b90
int32 callback client address=0x5d2d00, addr=0, reason=11, userPvt=0x153a4a0
int32 callback client address=0x5d2d00, addr=0, reason=12, userPvt=0x153b1a0
int32 callback client address=0x5d2d00, addr=0, reason=13, userPvt=0x153bab0
int32 callback client address=0x5d2d00, addr=0, reason=14, userPvt=0x153c3c0
int32 callback client address=0x5d2d00, addr=0, reason=25, userPvt=0x153ccd0
int32 callback client address=0x5d2d00, addr=0, reason=19, userPvt=0x153d5e0
int32 callback client address=0x5d2d00, addr=0, reason=21, userPvt=0x153def0
int32 callback client address=0x5d2d00, addr=0, reason=22, userPvt=0x153e800
int32 callback client address=0x5d2d00, addr=0, reason=26, userPvt=0x153f110
int32 callback client address=0x5d2d00, addr=0, reason=59, userPvt=0x1541030
int32 callback client address=0x5d2d00, addr=0, reason=67, userPvt=0x1541940
int32 callback client address=0x5d2d00, addr=0, reason=68, userPvt=0x1542d60
int32 callback client address=0x5d2d00, addr=0, reason=61, userPvt=0x1543670
int32 callback client address=0x5d2d00, addr=0, reason=62, userPvt=0x1543f80
int32 callback client address=0x5d2d00, addr=0, reason=63, userPvt=0x1544890
int32 callback client address=0x5d2d00, addr=0, reason=64, userPvt=0x15451a0
int32 callback client address=0x5d2d00, addr=0, reason=65, userPvt=0x1545ab0
int32 callback client address=0x5d2d00, addr=0, reason=66, userPvt=0x15463c0
int32 callback client address=0x5d2d00, addr=0, reason=73, userPvt=0x1546cd0
int32 callback client address=0x5d2d00, addr=0, reason=74, userPvt=0x15479d0
int32 callback client address=0x5d2d00, addr=0, reason=75, userPvt=0x15482e0
int32 callback client address=0x5d2d00, addr=0, reason=76, userPvt=0x1548bf0
int32 callback client address=0x5d2d00, addr=0, reason=23, userPvt=0x178a760
int32 callback client address=0x5d2d00, addr=0, reason=17, userPvt=0x178b070
int32 callback client address=0x5d2d00, addr=0, reason=18, userPvt=0x178b980
int32 callback client address=0x5d2d00, addr=0, reason=49, userPvt=0x178c680
int32 callback client address=0x5d2d00, addr=0, reason=71, userPvt=0x178cf90
int32 callback client address=0x5d2d00, addr=0, reason=72, userPvt=0x178d8a0
int32 callback client address=0x5d2d00, addr=0, reason=81, userPvt=0x178e1b0
int32 callback client address=0x5d2d00, addr=0, reason=80, userPvt=0x178eac0
int32 callback client address=0x5d2d00, addr=0, reason=85, userPvt=0x178f3d0
float64 callback client address=0x5e0008, addr=0, reason=20, userPvt=0x16f12c0
float64 callback client address=0x5e0008, addr=0, reason=77, userPvt=0x16f28c0
float64 callback client address=0x5e0008, addr=0, reason=78, userPvt=0x16f30b0
float64 callback client address=0x5e0008, addr=0, reason=79, userPvt=0x16f38a0
float64 callback client address=0x5e0008, addr=0, reason=60, userPvt=0x16f4090
float64 callback client address=0x5e0008, addr=0, reason=86, userPvt=0x16f4880
float64 callback client address=0x5e0008, addr=0, reason=87, userPvt=0x16f5070
float64 callback client address=0x5e0008, addr=0, reason=88, userPvt=0x16f5860
float64 callback client address=0x5e0008, addr=0, reason=89, userPvt=0x16f6440
octet callback client address=0x5ccc30, addr=0, reason=91, userPvt=0x169c2d0
octet callback client address=0x5ccc30, addr=0, reason=92, userPvt=0x169c910
octet callback client address=0x5ccc30, addr=0, reason=93, userPvt=0x169cf50
octet callback client address=0x5ccc30, addr=0, reason=1, userPvt=0x1778df0
octet callback client address=0x5ccc30, addr=0, reason=2, userPvt=0x1779140
octet callback client address=0x5ccc30, addr=0, reason=0, userPvt=0x1779780
octet callback client address=0x5ccc30, addr=0, reason=3, userPvt=0x1779dc0
octet callback client address=0x5ccc30, addr=0, reason=4, userPvt=0x177a400
octet callback client address=0x5ccc30, addr=0, reason=5, userPvt=0x177aa40
octet callback client address=0x5ccc30, addr=0, reason=6, userPvt=0x177b080
octet callback client address=0x5ccc30, addr=0, reason=7, userPvt=0x177b6c0
octet callback client address=0x5ccc30, addr=0, reason=24, userPvt=0x177bd00
int32Array callback client address=0x5d9c10, addr=0, reason=16, userPvt=0x169b540
genericPointer callback client address=0x6d7640, addr=0, reason=51, userPvt=0x11f5aa0
genericPointer callback client address=0x6d7640, addr=1, reason=51, userPvt=0x136fad0
genericPointer callback client address=0x6d7640, addr=2, reason=51, userPvt=0x1376300
SIM1: private NDArrayPool report
NDArrayPool:
numBuffers=0, numFree=0
memorySize=0, maxMemory=0
freeList: (index, dataSize, pArray)
SIM1: pAttributeList report
NDAttributeList: address=0x11e6d40:
number of attributes=0
IPPORT1 multiDevice:No canBlock:Yes autoConnect:Yes
nDevices 0 nQueued 0 blocked:No
exceptionActive:No exceptionUsers 170 exceptionNotifys 0
asynOctet pinterface 0x117b870 drvPvt 0x11f3db0
interfaceList
asynCommon pinterface 0x113a550 drvPvt 0x11f39b0
asynOption pinterface 0x113a568 drvPvt 0x11f39b0
asynOctet pinterface 0x11f3ad0 drvPvt 0x11f39b0
Port 127.0.0.1:60000: Connected
fd: 4
Characters written: 5980
Characters read: 3919
Image1 multiDevice:No canBlock:No autoConnect:Yes
exceptionActive:No exceptionUsers 1 exceptionNotifys 0
asynOctet pinterface 0x117b720 drvPvt 0x11f4ef0
interfaceList
asynCommon pinterface 0x117ba40 drvPvt 0x11f5aa0
asynDrvUser pinterface 0x117ba58 drvPvt 0x11f5aa0
asynOctet pinterface 0x117bb18 drvPvt 0x11f5aa0
asynInt32 pinterface 0x117ba70 drvPvt 0x11f5aa0
asynFloat64 pinterface 0x117baf8 drvPvt 0x11f5aa0
asynInt8Array pinterface 0x117bb60 drvPvt 0x11f5aa0
asynInt16Array pinterface 0x117bb80 drvPvt 0x11f5aa0
asynInt32Array pinterface 0x117bba0 drvPvt 0x11f5aa0
asynInt64Array pinterface 0x117bbc0 drvPvt 0x11f5aa0
asynFloat32Array pinterface 0x117bbe0 drvPvt 0x11f5aa0
asynFloat64Array pinterface 0x117bc00 drvPvt 0x11f5aa0
asynGenericPointer pinterface 0x117bc20 drvPvt 0x11f5aa0
Port: Image1
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Number of parameters is: 81
Parameter 0 type=string, name=PORT_NAME_SELF, value=Image1, status=0
Parameter 2 type=string, name=DRIVER_VERSION, value=3.11.0, status=0
Parameter 11 type=asynInt32, name=ARRAY_SIZE_X, value=0, status=0
Parameter 12 type=asynInt32, name=ARRAY_SIZE_Y, value=0, status=0
Parameter 17 type=asynInt32, name=DATA_TYPE, value=0, status=0
Parameter 52 type=asynInt32, name=ARRAY_CALLBACKS, value=0, status=0
Parameter 60 type=string, name=NDARRAY_PORT, value=SIM1, status=0
Parameter 61 type=asynInt32, name=NDARRAY_ADDR, value=0, status=0
Parameter 62 type=string, name=PLUGIN_TYPE, value=NDPluginStdArrays, status=0
Parameter 63 type=asynInt32, name=DROPPED_ARRAYS, value=0, status=0
Parameter 64 type=asynInt32, name=QUEUE_SIZE, value=200, status=0
Parameter 65 type=asynInt32, name=QUEUE_FREE, value=200, status=0
Parameter 66 type=asynInt32, name=MAX_THREADS, value=5, status=0
Parameter 67 type=asynInt32, name=NUM_THREADS, value=1, status=0
Parameter 68 type=asynInt32, name=SORT_MODE, value=0, status=0
Parameter 69 type=asynFloat64, name=SORT_TIME, value=0.1, status=0
Parameter 70 type=asynInt32, name=SORT_SIZE, value=20, status=0
Parameter 71 type=asynInt32, name=SORT_FREE, value is undefined
Parameter 72 type=asynInt32, name=DISORDERED_ARRAYS, value=0, status=0
Parameter 73 type=asynInt32, name=DROPPED_OUTPUT_ARRAYS, value=0, status=0
Parameter 74 type=asynInt32, name=ENABLE_CALLBACKS, value=1, status=0
Parameter 75 type=asynInt32, name=BLOCKING_CALLBACKS, value=0, status=0
Parameter 76 type=asynInt32, name=PROCESS_PLUGIN, value is undefined
Parameter 77 type=asynFloat64, name=EXECUTION_TIME, value is undefined
Parameter 78 type=asynFloat64, name=MIN_CALLBACK_TIME, value=0, status=0
Parameter 79 type=asynFloat64, name=MAX_BYTE_RATE, value=0, status=0
Parameter 80 is undefined, name=STD_ARRAY_DATA
int32 callback client address=0x5d3780, addr=-1, reason=8, userPvt=0x168c140
int32 callback client address=0x5d2d00, addr=-1, reason=8, userPvt=0x15307d0
int32 callback client address=0x5d2d00, addr=-1, reason=9, userPvt=0x15310e0
int32 callback client address=0x5d2d00, addr=-1, reason=52, userPvt=0x15319f0
int32 callback client address=0x5d2d00, addr=-1, reason=74, userPvt=0x1532300
int32 callback client address=0x5d2d00, addr=-1, reason=75, userPvt=0x1532c10
int32 callback client address=0x5d2d00, addr=-1, reason=15, userPvt=0x1549500
int32 callback client address=0x5d2d00, addr=-1, reason=11, userPvt=0x1549e10
int32 callback client address=0x5d2d00, addr=-1, reason=12, userPvt=0x154a720
int32 callback client address=0x5d2d00, addr=-1, reason=13, userPvt=0x154b030
int32 callback client address=0x5d2d00, addr=-1, reason=14, userPvt=0x154b940
int32 callback client address=0x5d2d00, addr=-1, reason=25, userPvt=0x154cd60
int32 callback client address=0x5d2d00, addr=-1, reason=19, userPvt=0x154d670
int32 callback client address=0x5d2d00, addr=-1, reason=21, userPvt=0x154e370
int32 callback client address=0x5d2d00, addr=-1, reason=22, userPvt=0x154ec80
int32 callback client address=0x5d2d00, addr=-1, reason=26, userPvt=0x154f590
int32 callback client address=0x5d2d00, addr=-1, reason=59, userPvt=0x15510c0
int32 callback client address=0x5d2d00, addr=-1, reason=61, userPvt=0x15519d0
int32 callback client address=0x5d2d00, addr=-1, reason=63, userPvt=0x1657390
int32 callback client address=0x5d2d00, addr=-1, reason=64, userPvt=0x1657ca0
int32 callback client address=0x5d2d00, addr=-1, reason=65, userPvt=0x16585b0
int32 callback client address=0x5d2d00, addr=-1, reason=67, userPvt=0x16592b0
int32 callback client address=0x5d2d00, addr=-1, reason=66, userPvt=0x1659bc0
int32 callback client address=0x5d2d00, addr=-1, reason=70, userPvt=0x165a4d0
int32 callback client address=0x5d2d00, addr=-1, reason=71, userPvt=0x165ade0
int32 callback client address=0x5d2d00, addr=-1, reason=73, userPvt=0x165c200
int32 callback client address=0x5d2d00, addr=-1, reason=72, userPvt=0x165cb10
int32 callback client address=0x5d2d00, addr=-1, reason=23, userPvt=0x178fce0
int32 callback client address=0x5d2d00, addr=-1, reason=17, userPvt=0x17905f0
int32 callback client address=0x5d2d00, addr=-1, reason=18, userPvt=0x1790f00
int32 callback client address=0x5d2d00, addr=-1, reason=49, userPvt=0x1791810
int32 callback client address=0x5d2d00, addr=-1, reason=68, userPvt=0x1792510
float64 callback client address=0x5e0008, addr=-1, reason=20, userPvt=0x16f84e0
float64 callback client address=0x5e0008, addr=-1, reason=78, userPvt=0x16f9dc0
float64 callback client address=0x5e0008, addr=-1, reason=79, userPvt=0x16fa5b0
float64 callback client address=0x5e0008, addr=-1, reason=77, userPvt=0x16fada0
float64 callback client address=0x5e0008, addr=-1, reason=69, userPvt=0x16fb590
octet callback client address=0x5ccc30, addr=-1, reason=1, userPvt=0x177c340
octet callback client address=0x5ccc30, addr=-1, reason=2, userPvt=0x177d450
octet callback client address=0x5ccc30, addr=-1, reason=0, userPvt=0x177da90
octet callback client address=0x5ccc30, addr=-1, reason=3, userPvt=0x177e0d0
octet callback client address=0x5ccc30, addr=-1, reason=4, userPvt=0x177e710
octet callback client address=0x5ccc30, addr=-1, reason=5, userPvt=0x177ed50
octet callback client address=0x5ccc30, addr=-1, reason=6, userPvt=0x177f390
octet callback client address=0x5ccc30, addr=-1, reason=7, userPvt=0x177f9d0
octet callback client address=0x5ccc30, addr=-1, reason=24, userPvt=0x1780010
octet callback client address=0x5ccc30, addr=-1, reason=62, userPvt=0x1780650
octet callback client address=0x5ccc30, addr=-1, reason=60, userPvt=0x1780c90
int32Array callback client address=0x5d9c10, addr=-1, reason=16, userPvt=0x169db40
int32Array callback client address=0x5d9c10, addr=-1, reason=80, userPvt=0x169ecc0
Image1: private NDArrayPool report
NDArrayPool:
Image1: pAttributeList report
NDAttributeList: address=0x1450da0:
Image2 multiDevice:No canBlock:No autoConnect:Yes
asynOctet pinterface 0x117b720 drvPvt 0x1231fa0
interfaceList
asynCommon pinterface 0x117ba40 drvPvt 0x136fad0
asynDrvUser pinterface 0x117ba58 drvPvt 0x136fad0
asynOctet pinterface 0x117bb18 drvPvt 0x136fad0
asynInt32 pinterface 0x117ba70 drvPvt 0x136fad0
asynFloat64 pinterface 0x117baf8 drvPvt 0x136fad0
asynInt8Array pinterface 0x117bb60 drvPvt 0x136fad0
asynInt16Array pinterface 0x117bb80 drvPvt 0x136fad0
asynInt32Array pinterface 0x117bba0 drvPvt 0x136fad0
asynInt64Array pinterface 0x117bbc0 drvPvt 0x136fad0
asynFloat32Array pinterface 0x117bbe0 drvPvt 0x136fad0
asynFloat64Array pinterface 0x117bc00 drvPvt 0x136fad0
asynGenericPointer pinterface 0x117bc20 drvPvt 0x136fad0
Port: Image2
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Parameter 0 type=string, name=PORT_NAME_SELF, value=Image2, status=0
Parameter 61 type=asynInt32, name=NDARRAY_ADDR, value=1, status=0
int32 callback client address=0x5d3780, addr=-1, reason=8, userPvt=0x1691280
int32 callback client address=0x5d2d00, addr=-1, reason=8, userPvt=0x1533520
int32 callback client address=0x5d2d00, addr=-1, reason=9, userPvt=0x1533e30
int32 callback client address=0x5d2d00, addr=-1, reason=52, userPvt=0x1534740
int32 callback client address=0x5d2d00, addr=-1, reason=74, userPvt=0x1535050
int32 callback client address=0x5d2d00, addr=-1, reason=75, userPvt=0x1535960
int32 callback client address=0x5d2d00, addr=-1, reason=15, userPvt=0x165d420
int32 callback client address=0x5d2d00, addr=-1, reason=11, userPvt=0x165dd30
int32 callback client address=0x5d2d00, addr=-1, reason=12, userPvt=0x165e640
int32 callback client address=0x5d2d00, addr=-1, reason=13, userPvt=0x165ef50
int32 callback client address=0x5d2d00, addr=-1, reason=14, userPvt=0x165fc50
int32 callback client address=0x5d2d00, addr=-1, reason=25, userPvt=0x1660560
int32 callback client address=0x5d2d00, addr=-1, reason=19, userPvt=0x1660e70
int32 callback client address=0x5d2d00, addr=-1, reason=21, userPvt=0x1661780
int32 callback client address=0x5d2d00, addr=-1, reason=22, userPvt=0x1662090
int32 callback client address=0x5d2d00, addr=-1, reason=26, userPvt=0x16629a0
int32 callback client address=0x5d2d00, addr=-1, reason=59, userPvt=0x16644d0
int32 callback client address=0x5d2d00, addr=-1, reason=61, userPvt=0x1664de0
int32 callback client address=0x5d2d00, addr=-1, reason=63, userPvt=0x16665f0
int32 callback client address=0x5d2d00, addr=-1, reason=64, userPvt=0x1666f00
int32 callback client address=0x5d2d00, addr=-1, reason=65, userPvt=0x1667810
int32 callback client address=0x5d2d00, addr=-1, reason=67, userPvt=0x1668120
int32 callback client address=0x5d2d00, addr=-1, reason=66, userPvt=0x1668a30
int32 callback client address=0x5d2d00, addr=-1, reason=70, userPvt=0x1669340
int32 callback client address=0x5d2d00, addr=-1, reason=71, userPvt=0x1669c50
int32 callback client address=0x5d2d00, addr=-1, reason=73, userPvt=0x166a560
int32 callback client address=0x5d2d00, addr=-1, reason=72, userPvt=0x166ae70
int32 callback client address=0x5d2d00, addr=-1, reason=23, userPvt=0x1792e20
int32 callback client address=0x5d2d00, addr=-1, reason=17, userPvt=0x1793730
int32 callback client address=0x5d2d00, addr=-1, reason=18, userPvt=0x1794b50
int32 callback client address=0x5d2d00, addr=-1, reason=49, userPvt=0x1795460
int32 callback client address=0x5d2d00, addr=-1, reason=68, userPvt=0x1795d70
float64 callback client address=0x5e0008, addr=-1, reason=20, userPvt=0x16fbd80
float64 callback client address=0x5e0008, addr=-1, reason=78, userPvt=0x16fd940
float64 callback client address=0x5e0008, addr=-1, reason=79, userPvt=0x16fe130
float64 callback client address=0x5e0008, addr=-1, reason=77, userPvt=0x16fe920
float64 callback client address=0x5e0008, addr=-1, reason=69, userPvt=0x16ff110
octet callback client address=0x5ccc30, addr=-1, reason=1, userPvt=0x17812d0
octet callback client address=0x5ccc30, addr=-1, reason=2, userPvt=0x1781910
octet callback client address=0x5ccc30, addr=-1, reason=0, userPvt=0x1781f50
octet callback client address=0x5ccc30, addr=-1, reason=3, userPvt=0x1782590
octet callback client address=0x5ccc30, addr=-1, reason=4, userPvt=0x1782bd0
octet callback client address=0x5ccc30, addr=-1, reason=5, userPvt=0x1783210
octet callback client address=0x5ccc30, addr=-1, reason=6, userPvt=0x1783850
octet callback client address=0x5ccc30, addr=-1, reason=7, userPvt=0x1783e90
octet callback client address=0x5ccc30, addr=-1, reason=24, userPvt=0x17844d0
octet callback client address=0x5ccc30, addr=-1, reason=62, userPvt=0x1784b10
octet callback client address=0x5ccc30, addr=-1, reason=60, userPvt=0x1785150
int32Array callback client address=0x5d9c10, addr=-1, reason=16, userPvt=0x169f820
int32Array callback client address=0x5d9c10, addr=-1, reason=80, userPvt=0x16a05b0
Image2: private NDArrayPool report
NDArrayPool:
Image2: pAttributeList report
NDAttributeList: address=0x13712d0:
Image multiDevice:No canBlock:No autoConnect:Yes
asynOctet pinterface 0x117b720 drvPvt 0x157d0a0
interfaceList
asynCommon pinterface 0x117ba40 drvPvt 0x1376300
asynDrvUser pinterface 0x117ba58 drvPvt 0x1376300
asynOctet pinterface 0x117bb18 drvPvt 0x1376300
asynInt32 pinterface 0x117ba70 drvPvt 0x1376300
asynFloat64 pinterface 0x117baf8 drvPvt 0x1376300
asynInt8Array pinterface 0x117bb60 drvPvt 0x1376300
asynInt16Array pinterface 0x117bb80 drvPvt 0x1376300
asynInt32Array pinterface 0x117bba0 drvPvt 0x1376300
asynInt64Array pinterface 0x117bbc0 drvPvt 0x1376300
asynFloat32Array pinterface 0x117bbe0 drvPvt 0x1376300
asynFloat64Array pinterface 0x117bc00 drvPvt 0x1376300
asynGenericPointer pinterface 0x117bc20 drvPvt 0x1376300
Port: Image
Input EOS[0]:
Output EOS[0]:
Parameter list 0
Parameter 0 type=string, name=PORT_NAME_SELF, value=Image, status=0
Parameter 61 type=asynInt32, name=NDARRAY_ADDR, value=2, status=0
int32 callback client address=0x5d3780, addr=-1, reason=8, userPvt=0x1695b20
int32 callback client address=0x5d2d00, addr=-1, reason=8, userPvt=0x1536270
int32 callback client address=0x5d2d00, addr=-1, reason=9, userPvt=0x1536b80
int32 callback client address=0x5d2d00, addr=-1, reason=52, userPvt=0x1537490
int32 callback client address=0x5d2d00, addr=-1, reason=74, userPvt=0x15388b0
int32 callback client address=0x5d2d00, addr=-1, reason=75, userPvt=0x15391c0
int32 callback client address=0x5d2d00, addr=-1, reason=15, userPvt=0x166b780
int32 callback client address=0x5d2d00, addr=-1, reason=11, userPvt=0x166c480
int32 callback client address=0x5d2d00, addr=-1, reason=12, userPvt=0x166cd90
int32 callback client address=0x5d2d00, addr=-1, reason=13, userPvt=0x166d6a0
int32 callback client address=0x5d2d00, addr=-1, reason=14, userPvt=0x166dfb0
int32 callback client address=0x5d2d00, addr=-1, reason=25, userPvt=0x166e8c0
int32 callback client address=0x5d2d00, addr=-1, reason=19, userPvt=0x166f1d0
int32 callback client address=0x5d2d00, addr=-1, reason=21, userPvt=0x16705f0
int32 callback client address=0x5d2d00, addr=-1, reason=22, userPvt=0x1670f00
int32 callback client address=0x5d2d00, addr=-1, reason=26, userPvt=0x1671810
int32 callback client address=0x5d2d00, addr=-1, reason=59, userPvt=0x1673730
int32 callback client address=0x5d2d00, addr=-1, reason=61, userPvt=0x1674040
int32 callback client address=0x5d2d00, addr=-1, reason=63, userPvt=0x1674950
int32 callback client address=0x5d2d00, addr=-1, reason=64, userPvt=0x1675260
int32 callback client address=0x5d2d00, addr=-1, reason=65, userPvt=0x1675b70
int32 callback client address=0x5d2d00, addr=-1, reason=67, userPvt=0x1676480
int32 callback client address=0x5d2d00, addr=-1, reason=66, userPvt=0x1676d90
int32 callback client address=0x5d2d00, addr=-1, reason=70, userPvt=0x16776a0
int32 callback client address=0x5d2d00, addr=-1, reason=71, userPvt=0x1677fb0
int32 callback client address=0x5d2d00, addr=-1, reason=73, userPvt=0x1678cb0
int32 callback client address=0x5d2d00, addr=-1, reason=72, userPvt=0x16795c0
int32 callback client address=0x5d2d00, addr=-1, reason=23, userPvt=0x1796680
int32 callback client address=0x5d2d00, addr=-1, reason=17, userPvt=0x1796f90
int32 callback client address=0x5d2d00, addr=-1, reason=18, userPvt=0x17978a0
int32 callback client address=0x5d2d00, addr=-1, reason=49, userPvt=0x17981b0
int32 callback client address=0x5d2d00, addr=-1, reason=68, userPvt=0x1798eb0
float64 callback client address=0x5e0008, addr=-1, reason=20, userPvt=0x16ff900
float64 callback client address=0x5e0008, addr=-1, reason=78, userPvt=0x1701be0
float64 callback client address=0x5e0008, addr=-1, reason=79, userPvt=0x1706b40
float64 callback client address=0x5e0008, addr=-1, reason=77, userPvt=0x17076e0
float64 callback client address=0x5e0008, addr=-1, reason=69, userPvt=0x1707ed0
octet callback client address=0x5ccc30, addr=-1, reason=1, userPvt=0x1785790
octet callback client address=0x5ccc30, addr=-1, reason=2, userPvt=0x1785dd0
octet callback client address=0x5ccc30, addr=-1, reason=0, userPvt=0x1786410
octet callback client address=0x5ccc30, addr=-1, reason=3, userPvt=0x1786a50
octet callback client address=0x5ccc30, addr=-1, reason=4, userPvt=0x1787090
octet callback client address=0x5ccc30, addr=-1, reason=5, userPvt=0x17876d0
octet callback client address=0x5ccc30, addr=-1, reason=6, userPvt=0x1787d10
octet callback client address=0x5ccc30, addr=-1, reason=7, userPvt=0x1788350
octet callback client address=0x5ccc30, addr=-1, reason=24, userPvt=0x1788990
octet callback client address=0x5ccc30, addr=-1, reason=62, userPvt=0x1788fd0
octet callback client address=0x5ccc30, addr=-1, reason=60, userPvt=0x1789610
int32Array callback client address=0x5d9c10, addr=-1, reason=16, userPvt=0x16a1110
int32Array callback client address=0x5d9c10, addr=-1, reason=80, userPvt=0x16a1ea0
Image: private NDArrayPool report
NDArrayPool:
Image: pAttributeList report
NDAttributeList: address=0x1374810:
