Hi, Recently, I was going to use the S7nodave to connect the PLC device, There was a sentence in the manual that make me confused . The manual said :S7nodave must be compiled with a C++ compiler that supports C++ 11. For some compilers, C++ 11 support is not enabled by default. In this case, you have to add the file configure/CONFIG_SITE.local and append the appropriate compiler options to the USR_CXXFLAGS variable. An example for such a configuration file can be found in configure/EXAMPLE_CONFIG_SITE.local .I have two questions about this sentence: 1. My computer's compiler does not support C++11, can I install boost insteal of c++ 11. Do I have to install C++ compiler that supports C++ 11? 2. How to add the file configure/CONFIG_SITE.local and append the appropriate compiler options to the USR_CXXFLAGS variable, I haven't see any example.Thanks White
ANJ, 22 Feb 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
