1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: AW: [External] Support with EPICS-based applications
From: Chitra Venkataraman via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Feb 2023 14:16:25 +0000
Our specified interest in a student to support us with epics applications was guided mainly by the expectation that the work will be intermittent, in smaller packages, should not cause any conflict of interest and of fairly limited complexity. At this point, we don’t anticipate site-visits will be needed and that the work can be done remotely, but this might change depending on how the interaction develops.
Thanks
Chitra
Von: Maren Purves [mailto:m.purves at eaobservatory.org]
Gesendet: Freitag, 24. Februar 2023 18:41
An: Leblanc, Gregory <leblanc at ohio.edu>
Cc: Chitra Venkataraman <chitra.venkataraman at axilon.de>; tech-talk at aps.anl.gov
Betreff: Re: [External] Support with EPICS-based applications
More questions:
Is there a reason why they have to be students?
Are there fixed working hours? (which may affect, if they don't have to be on site, which time zones would be convenient to accommodate that)
Maren
On Fri, Feb 24, 2023 at 7:37 AM Leblanc, Gregory via Tech-talk <tech-talk at aps.anl.gov> wrote:
Chitra,
Are you looking for undergraduate or graduate students?  Are you expecting that folks will need to be on-site, or can this work be accomplished remotely?  Thanks,
     Greg
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701 USA
leblanc at ohio.edu
M: (401) 52-OUAL1 or (401) 526-8251
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Chitra Venkataraman via Tech-talk
Sent: Friday, February 24, 2023 5:37 AM
To: tech-talk at aps.anl.gov
Subject: [External] Support with EPICS-based applications
Use caution with links and attachments.
AXILON is looking for a student who would be interested in supporting us with short-term EPICS projects, specifically creating EPICS IOCs for control of components built by AXILON. This would involve integrating relevant field signals like motor control, encoder, analog I/Os via PLCs, some scripting using e.g. Python, C, C++, and developing user interfaces. To a large extent, existing EPICS modules can be used to interface to the control hardware, however custom development may also be required in specific cases. If interested, please contact us at info at axilon.de.
Support with EPICS-based applications Chitra Venkataraman via Tech-talk
RE: [External] Support with EPICS-based applications Leblanc, Gregory via Tech-talk
Re: [External] Support with EPICS-based applications Maren Purves via Tech-talk
Prev: pilatusDetector Error: access denied 张禹浦 via Tech-talk
Next: AW: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Eckert, Sebastian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: [External] Support with EPICS-based applications Maren Purves via Tech-talk
Next: AreaDetector, order of DetectorState_RBV and AcquireBusy Sebastian Eckert via Tech-talk
ANJ, 28 Feb 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
