Subject: |
AreaDetector, order of DetectorState_RBV and AcquireBusy |
Sebastian Eckert via Tech-talk <[email protected]> |
To: |
Date: |
Fri, 24 Feb 2023 12:50:18 +0100 |
we are using AreaDetector with an Andor IKON usb 2.0 camera. Acquisitions are triggered with a monitor on the AcquireBusy field and wait for plugins enabled which should guarantee that the camera and all connected routines are done before a new acquisition is triggered (the only active plugins are image and the HDF5). Frequently we have cases where AcquireBusy has returned already to zero after an acquisition, while the DetectorState_RBV is still 1. This condition is present for roughly 10ms.
In these cases a new trigger sets AcquireBusy to 1 while DetectorState_RBV eventually goes to zero after the completed (previous) acquisition. A fresh camera image is not taken and AcquireBusy stays 1 until aborted manually.
As a workaround, we can also monitor DetectorState_RBV to guarantee it is 0 before triggering a new acquisition.
Is this behavior expected, or should the scenario AcquireBusy=0 and DetectorState_RBV=1 not be possible?
Best
Sebastian
smime.p7s
Description: S/MIME cryptographic signature
- RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Pearson, Matthew via Tech-talk
Support with EPICS-based applications Chitra Venkataraman via Tech-talk
Periodic scan Issue with PV record scan type as IO Intr Arnab Dasgupta via Tech-talk
<2023>
2025
2026
AW: [External] Support with EPICS-based applications Chitra Venkataraman via Tech-talk
<2023>
2025
2026
