1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
From: "Pearson, Matthew via Tech-talk" <[email protected]>
To: Sebastian Eckert <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Feb 2023 17:21:41 +0000
In that driver the DetectorState_RBV is updated via a function called statusTask that runs in its own thread. It monitors the detector state (using the Andor SDK function GetStatus) and the sensor temperature sensors and cooling system. The image readout is done in a different thread using a function called dataTask, which also updates the ADAcquire parameter, which controls the callback and the state of the AcquireBusy record.
So I think it's possible that the acquisition has finished (and all the plugins have completed execution), and then AcquireBusy is set back to 0, but the DetectorState_RBV is still 1 either because statusTask has not run yet or the detector really is still busy for a few milliseconds after the image readout has been completed.
If I look at the Andor SDK user manual I see this in the section for the SDK function GetStatus:
This function will return the current status of the Andor SDK system. This function should
be called before an acquisition is started to ensure that it is IDLE and during an acquisition
to monitor the process
which implies that we can't start a new acquisition until GetStatus reports Idle.
I can't remember now if I've tested sequences of ADAcquire commands with no delay in between them. However, the driver does check the ADStatus parameter (obtained from the SDK GetStatus, and which also corresponds to DetectorState_RBV) before allowing a new acquisition to start. In this case, if ADStatus is still reporting busy, it doesn't start an acquisition and it also doesn't set the ADAcquire back to zero, so the AcquireBusy record gets stuck in busy state.
As an interim solution, a short delay between image acquisitions will help fix this problem, or also monitor the DetectorState_RBV value as you mentioned.
Perhaps the driver should not complete image acquisition by setting ADAcquire back to 0 until the detector state also reports Idle.
Cheers,
Matt
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Sebastian Eckert via Tech-talk
Sent: Friday, February 24, 2023 6:50 AM
To: [email protected]
Subject: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy
we are using AreaDetector with an Andor IKON usb 2.0 camera. Acquisitions are triggered with a monitor on the AcquireBusy field and wait for plugins enabled which should guarantee that the camera and all connected routines are done before a new acquisition is triggered (the only active plugins are image and the HDF5). Frequently we have cases where AcquireBusy has returned already to zero after an acquisition, while the DetectorState_RBV is still 1. This condition is present for roughly 10ms.
In these cases a new trigger sets AcquireBusy to 1 while DetectorState_RBV eventually goes to zero after the completed (previous) acquisition. A fresh camera image is not taken and AcquireBusy stays 1 until aborted manually.
As a workaround, we can also monitor DetectorState_RBV to guarantee it is 0 before triggering a new acquisition.
Is this behavior expected, or should the scenario AcquireBusy=0 and DetectorState_RBV=1 not be possible?
Best
Sebastian
RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
AreaDetector, order of DetectorState_RBV and AcquireBusy Sebastian Eckert via Tech-talk
Prev: Periodic scan Issue with PV record scan type as IO Intr Arnab Dasgupta via Tech-talk
Next: RE: [External] Support with EPICS-based applications Leblanc, Gregory via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: AreaDetector, order of DetectorState_RBV and AcquireBusy Sebastian Eckert via Tech-talk
Next: RE: [EXTERNAL] AreaDetector, order of DetectorState_RBV and AcquireBusy Mark Rivers via Tech-talk
