On 3/3/23 23:38, Luchini, Kristi L. via Tech-talk wrote:
Hello,
I’m upgrading an EPICS IOC Application from epics base R3.14.12 to R7.0.3.1-1.0, and I’ve noticed a different behavior on boot regarding the DOL field of an output record. For example for an aoRecord, in R3.14.12 if you set DOL=”” on boot the VAL field will be restored. If, DOL is a link then the value of that PV will be restored in the ao. However, in R7.0.3.1-1.0 , if DOL=”” a 0 is restored, independent of the VAL field. Only if I don’t specify the DOL field in the db, will the VAL field be restored on boot.
Is there a reason this behavior has changed? To me the R3.14.12 behavior seems to be correct.
If I have correctly understand the situation you describe,
then this change was not intentional.
Can you see if this change results in the behavior you expect?
https://github.com/epics-base/epics-base/pull/335
- RE: base R7.0.3.1-1.0 db field DOL="" different behavior then in R3.14.12 Luchini, Kristi L. via Tech-talk
- base R7.0.3.1-1.0 db field DOL="" different behavior then in R3.14.12 Luchini, Kristi L. via Tech-talk
<2023>
<2023>
