Hi Michel,
I loaded you're test database below:
record(longout, "lo1") {
field(DOL, "")
field(VAL, "42")
record(longout, "lo2") {
field(VAL, "42")
record(longout, "lo3") {
field(DOL, "42")
Here's what I see:
- Kristi
-----Original Mess [luchini@lcls-dev3 ~]$ caget lo1
lo1 0
[luchini@lcls-dev3 ~]$ caget lo2
lo2 42
[luchini@lcls-dev3 ~]$ caget lo3
lo3 42
-Kristi
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Monday, March 6, 2023 8:14 AM
To: Luchini, Kristi L. <luchini at slac.stanford.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: base R7.0.3.1-1.0 db field DOL="" different behavior then in R3.14.12
On 3/3/23 23:38, Luchini, Kristi L. via Tech-talk wrote:
> Hello,
> I’m upgrading an EPICS IOC Application from epics base R3.14.12 to R7.0.3.1-1.0, and I’ve noticed a different behavior on boot regarding the DOL field of an output record. For example for an aoRecord, in R3.14.12 if you set DOL=”” on boot the VAL field will be restored. If, DOL is a link then the value of that PV will be restored in the ao. However, in R7.0.3.1-1.0 , if DOL=”” a 0 is restored, independent of the VAL field. Only if I don’t specify the DOL field in the db, will the VAL field be restored on boot.
> Is there a reason this behavior has changed? To me the R3.14.12 behavior seems to be correct.
If I have correctly understand the situation you describe, then this change was not intentional.
Can you see if this change results in the behavior you expect?
https://github.com/epics-base/epics-base/pull/335
- base R7.0.3.1-1.0 db field DOL="" different behavior then in R3.14.12 Luchini, Kristi L. via Tech-talk
- Re: base R7.0.3.1-1.0 db field DOL="" different behavior then in R3.14.12 Michael Davidsaver via Tech-talk
RE: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection Wang, Andrew via Tech-talk
<2023>
<2023>
