Hi William,
Your error is coming when building the nanohttp_stream.dll. That depends on xml2.lib, which is built earlier in that same Makefile if XML2_EXTERNAL is defined to be NO.
2 questions:
- Is XML2_EXTERNAL defined to be NO in areaDetector/configure/CONFIG_SITE.local?
- Just before you get that error do you see xml2.lib being built? Does it exist in the ADSupport/lib/windows-x64 directory?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of William Kirstaedter via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, March 7, 2023 5:25 AM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: areadetector on windows, xml2
I would like to use areadetector on windows, in combination with
Princeton Lightfield Software.
when compiling ADSupport, it fails with an error regarding xml2 library.
make[3]: Entering directory
'C:/EPICS/epics-support/areaDetector/ADSupport/supportApp/xml2Src/O.windows-x64'
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release -MACHINE:X64 -out:nanohttp_stream.dll
-implib:nanohttp_stream.lib nanohttp_stream.obj xml2.lib
ws2_32.lib
LINK : fatal error LNK1181: cannot open input file 'xml2.lib'
make[3]: *** [C:/EPICS/epics-base/configure/RULES_BUILD:316:
nanohttp_stream.dll] Error 1181
make[3]: Leaving directory
make[2]: *** [C:/EPICS/epics-base/configure/RULES_ARCHS:58:
install.windows-x64] Error 2
make[2]: Leaving directory
'C:/EPICS/epics-support/areaDetector/ADSupport/supportApp/xml2Src'
make[1]: *** [C:/EPICS/epics-base/configure/RULES_DIRS:85:
xml2Src.install] Error 2
make[1]: Leaving directory
'C:/EPICS/epics-support/areaDetector/ADSupport/supportApp'
make: *** [C:/EPICS/epics-base/configure/RULES_DIRS:85:
supportApp.install] Error 2
the manual states that since R2-5, the support package holds source code
for xml2 lib.
clearly, it tries to compile but fails. is it a known issue?
Am I doing it wrong?
Should I fulfill other prerequisites before compiling AD Stuff?
I'd be happy to get some hints,
thanks in advance!
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: kirstaedter at fhi-berlin.mpg.de
- Re: areadetector on windows, xml2 William Kirstaedter via Tech-talk
- areadetector on windows, xml2 William Kirstaedter via Tech-talk
Re: Re:Re: Segmentation fault (core dumped) using SimDetector ioc Mark Rivers via Tech-talk
CSS Main Display screen size Patel, Anjali Himanshukumar via Tech-talk
<2023>
2025
<2023>
2025
ANJ, 09 Mar 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
