Folks,
I found a rather ugly solution.
- I had Doxygen put its output in docs/doxygenHTML
- I added these 2 lines to docs/source/conf.py
html_extra_path = ['../doxygenHTML']
exclude_patterns = ['index.html']
The first line tells Sphinx to copy all of the files in doxygenHTML/ to _build/html when it builds. There seems to be no way to tell Sphinx to put the files in a subfolder,
so there will be a conflict with index.html, which exists both for the Sphinx build and for the Doxygen build. So the second line tells Sphinx to exclude copying the Doxygen index.html file. In this specific case that is OK, because I had no useful information
on the main Doxygen page, but in general this would be a serious issue.
I also had to add these lines to my Github Actions publish-docs.yml file after the Doxygen build:
- name: Change Doxygen output permissions so Sphinx can delete
run: |
sudo chmod -R 777 docs/doxygenHTML
That is because Doxygen creates files owned by root, and Sphinx cannot delete them without changing their permissions.
It seems like there should be a better way to do this, so I am happy to hear any suggestions!
Sent: Wednesday, March 8, 2023 4:30 PM
To: tech-talk at aps.anl.gov
Cc: Jemian, Pete R. <jemian at anl.gov>
Subject: Sphinx Github actions problem
Folks,
I am trying to build the asyn Web pages with Github Actions. I need to do 2 things:
- Run doxygen to build the source code documentation
- Run Sphinx to build the human-generated documentation
Both of these work separately, but not together. If I run the Doxygen build first, it generates the output files fine. But then the Sphinx build (sphinx-notes/pages@v2)
tries to delete all of the files that Doxygen generated. I have tried having the Doxygen output go into the following locations:
/docs/doxygenOutput
/doxygenOutput
/docs/source/_static/doxygenOutput
In all cases Doxygen works fine, but then the Sphinx build tries to delete the Doxygen files. The Sphinx build the actually fails because the doxygen generated files are
owned by root. But even if it succeeded it would not work, since those files need to remain after the build.
If I run the Sphinx build first then Doxygen fails because the Sphinx build has already deleted the docs/ directory containing the Doxyfile.
Any idea solve this?
