1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Sphinx Github actions problem
Date: Wed, 8 Mar 2023 22:29:43 +0000
Folks,
I am trying to build the asyn Web pages with Github Actions.  I need to do 2 things:
  • Run doxygen to build the source code documentation
  • Run Sphinx to build the human-generated documentation
Both of these work separately, but not together.  If I run the Doxygen build first, it generates the output files fine.  But then the Sphinx build (sphinx-notes/pages@v2) tries to delete all of the files that Doxygen generated.  I have tried having the Doxygen output go into the following locations:
/docs/doxygenOutput
/doxygenOutput
/docs/source/_static/doxygenOutput
In all cases Doxygen works fine, but then the Sphinx build tries to delete the Doxygen files.  The Sphinx build the actually fails because the doxygen generated files are owned by root. But even if it succeeded it would not work, since those files need to remain after the build.
If I run the Sphinx build first then Doxygen fails because the Sphinx build has already deleted the docs/ directory containing the Doxyfile.
Any idea solve this?
RE: Sphinx Github actions problem Mark Rivers via Tech-talk
Prev: Virtual Motor Controller lynn via Tech-talk
Next: RE: Sphinx Github actions problem Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
