Mark, thank you very much.
Sent: Thursday, March 23, 2023 6:42 AM
To: EPICS tech-talk <tech-talk at aps.anl.gov>; Wang, Andrew <wang126 at llnl.gov>
Subject: Re: Differences between using disconnectOnReadTime in asynSetOption and asyn record
> Is there a difference between the two approaches for disconnecting a port upon a read
timeout?
No, there is no difference. The asynRecord simply calls the setOption() method in the
asynOption interface to the driver in this line:
case asynRecordDRTO:
status = pasynRecPvt->pasynOption->setOption(pasynRecPvt->asynOptionPvt,
pasynUser, "disconnectOnReadTimeout", drto_choices[pasynRec->drto]);
- Differences between using disconnectOnReadTime in asynSetOption and asyn record Wang, Andrew via Tech-talk
- Re: Differences between using disconnectOnReadTime in asynSetOption and asyn record Mark Rivers via Tech-talk
Re: [EXTERNAL] Fwd: MongoDB Implementation using EPICS 7 Kasemir, Kay via Tech-talk
Re: Other approaches to disabling a record from processing if there is no connection? Ralph Lange via Tech-talk
<2023>
2025
Other approaches to disabling a record from processing if there is no connection? Wang, Andrew via Tech-talk
<2023>
2025
ANJ, 23 Mar 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
