On 3/24/23 09:15, Andrew Johnson via Tech-talk wrote:
Hi Torsten,
On 3/24/23 10:07 AM, Torsten Bögershausen wrote:
I stumbled accross the same problem today.
I had over 100 emails in my inbox from our Jenkins CI-system about failing jobs because of this...
Why do you have 20 IP addresses ?
Shouldn't there simply be a hostname ?
That may be due to an architecture change on their side. In the past the github.com DNS entry had multiple IP addresses and the actual SSH server you talked to was picked at random from that list. Now it looks like there is only one IP address, and it's in a different range than the older addresses that appear in my known_hosts files. I'm deleting all of those other entries.
The view for me:
$ dig +noall +answer github.com
github.com. 31 IN A 192.30.255.113> $ dig +noall +answer -x 192.30.255.113
113.255.30.192.in-addr.arpa. 3419 IN PTR lb-192-30-255-113-sea.github.com.
I guess "lb-" abbreviates Load Balance.
It looks like my known_hosts file was hashed at some point, which complicates
cleaning out all of these IP entries in one go.
- GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
- Re: GitHub's new rsa ssh host-key Torsten Bögershausen via Tech-talk
- Re: GitHub's new rsa ssh host-key Andrew Johnson via Tech-talk
Re: Doubts about libpcre in compilation Marco A. Barra Montevechi Filho via Tech-talk
<2023>
2025
2026
Encoder Stall happens when increasing direction of motor pulses is opposite of that of encoder count Chiang, Liang-Chih [江良志] via Tech-talk
<2023>
2025
2026
