Hej Erwann,
I am not sure, if I understand you question.
Are you running under arm ?
And only find a lib for x86_64 (or so)
If yes:
You can compile EPICS base under arm, and the point out PYEPICS_LIBCA similar to this:
export PYEPICS_LIBCA=$EPICS_BASE/lib/$EPICS_HOST_ARCH/libca.dylib
(Obs: This is for Mac, under Linux it is probably xxx/yyy/libca.so )
HTH
/Torsten
> On 27 Mar 2023, at 13:57, LE-DANIEL Erwann via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hello,
> I tried hard to understand why pyepics doesn’t work on my odroid C4.
> I installed python version 3.8 and last pyepics version3.5.1
> Unfortunately, when I start python and after writing :
> import epics
> pv=epics.PV('VARIABLE')
> The return was :
> /home/odroid/.local/lib/python3.8/site-packages/epics/clibs/linux64/libca.so: cannot open shared object file: No such file or directory
> But in reality, the file is in the linux64 folder : /home/odroid/.local/lib/python3.8/site-packages/epics/clibs/linux64/
> I read in the page Downloading and Installation — Epics Channel Access for Python (uchicago.edu) that “ If these provided versions of libca do not work for you, please let us know. “ ..
> Where can I find other libca versions ?
> Many thanks.
> My environment : Ubuntu mate 20.0, python 3.8 , pyepics 3.5.1, cpu archi aarch64, hardware : odroid C4.
> Erwann.
> CONFIDENTIALITY : This e-mail and any attachments are confidential and may be privileged. If you are not a named recipient, please notify the sender immediately and do not disclose the contents to another person, use it for any purpose or store or copy the information in any medium.
- Error pyepics with odroid / libca.so cannot open shared object file. LE-DANIEL Erwann via Tech-talk
Re: Error pyepics with odroid / libca.so cannot open shared object file. Matt Newville via Tech-talk
<2023>
<2023>
