1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Links between bob files in different support modules
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "Kasemir, Kay" <kasemirk at ornl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Mar 2023 14:09:39 +0000
Hi Kay,
Just to check I have this right, if you had a button in motor_detail.bob that opened ls_overview.bob, then it would point to ../lakeshore/ls_overview.bob​? Would this require all downstream users of the motor module to use the same directory of symlinks for that link to work?
In case it is helpful, my use-case at the moment is something like areaDetector, where the detector support modules may want to link to bob files from the ADCore support module.
Tom
Sent: 28 March 2023 14:04
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Cobb, Tom (DLSLtd,RAL,LSCI) <tom.cobb at diamond.ac.uk>
I like the idea of using symlinks:
/some/path/main.bob
/some/path/motor/motor_overview.bob
/some/path/motor/motor_detail.bob
/some/path/lakeshore/ls_overview.bob
/some/path/lakeshore/ls_detail.bob
.. where motor is a symlink to ......../support_modules/..../motor/opi,
lakeshore is a symlink to ......../support_modules/..../lakeshore/opi
That way the display files are inside the support modules together with *.db, *.dbd and can be kept in git/cvs/... that way, while at the same time you have a display file tree where main.bob can open motor/motor_overview.bob with short relative links, and motor_overview.bob can trivially reach motor_detail.bob in the same folder.
It gets more complicated when you feel you need to keep several versions, so you end up with
/some/path/motor_v1/motor_overview.bob
/some/path/motor_v2/motor_overview.bob
/some/path/motor_v99/motor_overview.bob
Still, same ideas remain, just a larger display file tree with more symlinks to versioned copies of the support modules.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, March 28, 2023 6:02 AM
Subject: [EXTERNAL] Links between bob files in different support modules
Hi all,
We are looking at how to structure bob files within our support modules, especially how to link between support modules. For example, imagine we have a bob file ASupport/ASupportApp/op/bob/A_details.bob​ and we want to link to BSupport/BSupportApp/op/bob/B_details.bob​. As phoebus doesn't support a search path (for good reasons) we would need to supply an absolute or relative path to B_details.bob​ in A_details.bob​. My instinct is to use relative paths, so the directory tree can be served over http at runtime, but this means a link to ../../../BSupport/BSupportApp/op/bob/B_details.bob​ in A_details.bob​ which mandates that the two support modules be checked out next to each other.
Has anyone else had to link between bob files in two different support modules? If so, how have you done it?
Tom
RE: Links between bob files in different support modules Mark Rivers via Tech-talk
Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Links between bob files in different support modules Kasemir, Kay via Tech-talk
Prev: Re: Links between bob files in different support modules Kasemir, Kay via Tech-talk
Next: Re: Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: RE: Links between bob files in different support modules Mark Rivers via Tech-talk
ANJ, 28 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
