Hi Tom,
In case it is helpful, my use-case at the moment is something like areaDetector, where the detector support modules may want to link to bob files from the ADCore support module.
And the standard screens in both ADCore and AD support modules have links to the asynRecord screen from asyn, and some other synApps screens like yySeq_full.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of
Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Sent: Tuesday, March 28, 2023 9:10 AM
To: Kasemir, Kay <kasemirk at ornl.gov>; tech-talk at aps.anl.gov
Subject: Re: Links between bob files in different support modules
Just to check I have this right, if you had a button in motor_detail.bob that opened ls_overview.bob, then it would point to
../lakeshore/ls_overview.bob ? Would this require all downstream users of the motor module to use the same directory of symlinks for that link to
work?
module.
I like the idea of using symlinks:
/some/path/motor/motor_overview.bob
/some/path/motor/motor_detail.bob
/some/path/lakeshore/ls_overview.bob
/some/path/lakeshore/ls_detail.bob
.. where motor is a symlink to ......../support_modules/..../motor/opi,
lakeshore is a symlink to ......../support_modules/..../lakeshore/opi
That way the display files are inside the support modules together with *.db, *.dbd and can be kept in git/cvs/... that way, while at the same time you have a display file
tree where main.bob can open motor/motor_overview.bob with short relative links, and motor_overview.bob can trivially reach
motor_detail.bob in the same folder.
It gets more complicated when you feel you need to keep several versions, so you end up with
/some/path/motor_v1/motor_overview.bob
/some/path/motor_v2/motor_overview.bob
/some/path/motor_v99/motor_overview.bob
Still, same ideas remain, just a larger display file tree with more symlinks to versioned copies of the support modules.
We are looking at how to structure bob files within our support modules, especially how to link between support modules. For example, imagine we have a bob file
ASupport/ASupportApp/op/bob/A_details.bob and we want to link to
BSupport/BSupportApp/op/bob/B_details.bob . As phoebus doesn't support a search path (for
good reasons) we would need to supply an absolute or relative path to
B_details.bob in
A_details.bob . My instinct is to use relative paths, so the directory tree can be served over http at runtime, but this means a link to
../../../BSupport/BSupportApp/op/bob/B_details.bob in
A_details.bob which mandates that the two support modules be checked out next to each other.
Has anyone else had to link between bob files in two different support modules? If so, how have you done it?
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt
by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail.
- Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
- Re: Links between bob files in different support modules Kasemir, Kay via Tech-talk
- Re: Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
RE: MEDM font alias woes on Ubuntu 22 (Jammy) Mark Rivers via Tech-talk
RE: areadetector on windows, xml2 done, now Lightfield Mark Rivers via Tech-talk
<2023>
Re: Links between bob files in different support modules Andrew Johnson via Tech-talk
<2023>
