1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: How do I setEPICS opc UA security Settings?
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: 谭映雷 <tanyl at ihep.ac.cn>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Wed, 29 Mar 2023 15:58:07 +0200
Hello Yinglei Tan,
On Wed, 29 Mar 2023 at 14:49, 谭映雷 via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi:
When I set up the EPICS OPC UA client, the server did not receive the reject (.der) file, but I did receive certificates from the server.
What should I do to create a client certificate? Should the client certificate be copied to the server?
Any suggestions/solution approaches are welcome.
In the OPC UA Device Support sources, you will find a detailed README about how to configure OPC UA Security.
Setting up X.509-based security is not simple. It can be very frustrating, as any small mistake will make the connection fail, often without clear error messages.
I would suggest that you start with getting a good understanding of how these certificates and the PKI infrastructure work.
Once you know what is required, the information in the README will be hopefully enough to get you going. (It obviously includes descriptions of the tools and commands necessary to create client certificates.)
Feel free to directly contact me when you get stuck again. This topic might be too specialized to be discussed on tech-talk. I will update the README with any additional information that should be added.
Cheers,
~Ralph
Re: Re: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Prev: RE: areadetector on windows, xml2 done, now Lightfield Freddie Akeroyd - STFC UKRI via Tech-talk
Next: Re: Request for support: Error reading data in Epics Controls while modifying project Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
Next: Re: Re: How do I setEPICS opc UA security Settings? 谭映雷 via Tech-talk
ANJ, 30 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
