1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Request for support: Error reading data in Epics Controls while modifying project
From: Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov>
To: Grzegorz Lak <grzegorz.lak at s2innovation.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 29 Mar 2023 10:05:46 -0500
Grzegorz,
Which version of motor and motorPhytron are you using?
Kevin
On 3/27/23 09:13, Grzegorz Lak via Tech-talk wrote:
Good morning,
I am asking you for support in solving the problem we encountered while modifying our project. We've noticed an error reading data in Epics Controls and I need help fixing it.
The modification of the project consisted in reducing the number of supported stepper motors and did not include changes in the mechanics of the program's operation. When testing on the first two controllers, the same problem was obtained with reading the encoder counts. The encoder count reading is correct only in one direction, while in the opposite direction, when the measured displacement goes through "0", it immediately changes to a number corresponding to -2^31. Phymotion "Phylogic" software was used to test the functionality of the hardware: a stepper motor and an incremental encoder - the tests were successful.
PV type: motor
file "db/Phytron_motor.db"
patterns
{P, N, M, DTYP, PORT, ADDR, DESC, INIT, EGU, DIR, VELO, VBAS, HVEL, VMAX, ACCL, BDST, BVEL, BACC, MRES, ERES, RDBD, RCNT, PREC, DHLM, DLLM , UEIP} {PHYIOC:, 1, "m$(N)", "asynMotor", phyMotionPort, 11, "motor $(N)", "", urad, Pos, 50, 60, 60, 160 .4, 0, 100 , .2, 0.05, 0.010, 0.100, 10, 3, 8100, -8100, 1 }
file "db/Phytron_I1AM01.db"
patterns
{P, N, M, PORT, ADDR, SCAN, TIMEOUT, INIT, INIT_TIME, POS_TIME, HOMING, MODE, POS_OFFSET, NEG_OFFSET, SWITCH_TYP, PWR_STAGE, ENC_TYP, ENC_SFI, ENC_DIR, STOP_CURR, RUN_CURR, BOOST_CURR, BOOST, CURRENT_DELAY, HOPR , HIGH, HIHI, STEP_RES, PS_MON, MRES } {PHYIOC, 1,":m$(N)", phyMotionPort, 11, "1 second", 3, YES, 20, 20, 2, 1, 0, 0, 4, 1, 1, 0, 0, 50 , 1200, 1200, 0, 20, 1210, 1210, 1210, 1, 1, 0.05 }
Thank you in advance for taking the time to consider my request.
Kind regards,
*Grzegorz Lak*
Request for support: Error reading data in Epics Controls while modifying project Grzegorz Lak via Tech-talk
Prev: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
Next: Use Maven to build the phoebus project White via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Request for support: Error reading data in Epics Controls while modifying project Grzegorz Lak via Tech-talk
Next: Device support question Sinclair, John via Tech-talk
ANJ, 30 Mar 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
