Hello, If my problem is just because I overlooked some instructions, I apologize. system: Ubuntu 22.04.2 LTS epics base: epics-base-R7.0.7 (installed smoothly) synApps: wget https://raw.githubusercontent.com/EPICS-synApps/support/master/assemble_synApps.sh (installed smoothly after modifying EPICS_BASE) medm extensions: extensionsTop_20120904.tar.gz medm: tried both 'medm-MEDM3_1_17' and current git clone modifying made before medm/make: (1) set MOTIF_LIB and X11_LIB to /usr/lib/x86_64-linux-gnu in extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64, (2) in using 'USR_LIBS_Linux = Xm Xt Xmu X11 Xext' in medm/medm/Makefile (the modifications made the compile go further). Currently, the make error is (the ending part of make output): /usr/bin/gcc -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -Werror-implicit-function-declaration -DSCIPLOT -DMOTIF -DEDITRES -mtune=generic -m64 -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I/home/rong/EPICS/epics-base-R7.0.7/include/compiler/gcc -I/home/rong/EPICS/epics-base-R7.0.7/include/os/Linux -I/home/rong/EPICS/epics-base-R7.0.7/include -I../../printUtils -I../../xc -I/usr/include -I/usr/include -c ../xgif.c /usr/bin/g++ -o medm -L/home/rong/EPICS/extensions/lib/linux-x86_64 -L/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64 -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/home/rong/EPICS/extensions/lib/linux-x86_64 -Wl,-rpath,/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -rdynamic -m64 medmCartesianPlot.o medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXmu -lX11 -lXext /usr/bin/ld: cannot find -lXmu: No such file or directory collect2: error: ld returned 1 exit status make[2]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_BUILD:231: medm] Error 1 make[2]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm/O.linux-x86_64' make[1]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[1]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm' make: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_DIRS:85: medm.install] Error 2 Thank you in advance. Rong
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
