1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: linux medm installation error: cannot find -lXmu
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Rong Huang <ronghuang at ls-cat.org>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 31 Mar 2023 14:42:58 +0000
Not sure about Ubuntu 22.04
The "older" Ubuntus may have needed this:
sudo apt-get install -y libmotif-dev x11proto-print-dev xfonts-100dpi libxmu-dev libxpm-dev
And may be this helps:
https://epics.anl.gov/tech-talk/2018/msg02175.php
<https://github.com/EuropeanSpallationSource/medm/commit/bc992f873433af58ad32a3d735c18c47821368f3>
/Torsten
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Rong Huang via Tech-talk <tech-talk at aps.anl.gov>
Reply-To: Rong Huang <ronghuang at ls-cat.org>
Date: Friday, 31 March 2023 at 16:27
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: linux medm installation error: cannot find -lXmu
Hello,
If my problem is just because I overlooked some instructions, I apologize.
system:    Ubuntu 22.04.2 LTS
epics base:  epics-base-R7.0.7 (installed smoothly)
synApps:    wget https://raw.githubusercontent.com/EPICS-synApps/support/master/assemble_synApps.sh (installed smoothly after modifying EPICS_BASE)
medm extensions:  extensionsTop_20120904.tar.gz
medm: tried both 'medm-MEDM3_1_17' and current git clone
modifying made before medm/make:  (1) set MOTIF_LIB and X11_LIB to /usr/lib/x86_64-linux-gnu in extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64, (2) in using 'USR_LIBS_Linux = Xm Xt Xmu X11 Xext' in medm/medm/Makefile (the modifications made the compile go further).
Currently, the make error is (the ending part of make output):
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration    -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I/home/rong/EPICS/epics-base-R7.0.7/include/compiler/gcc -I/home/rong/EPICS/epics-base-R7.0.7/include/os/Linux -I/home/rong/EPICS/epics-base-R7.0.7/include          -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../xgif.c
/usr/bin/g++ -o medm  -L/home/rong/EPICS/extensions/lib/linux-x86_64 -L/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64 -L/usr/lib/x86_64-linux-gnu -Wl,-rpath,/home/rong/EPICS/extensions/lib/linux-x86_64 -Wl,-rpath,/home/rong/EPICS/epics-base-R7.0.7/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu          -rdynamic -m64          medmCartesianPlot.o medmSciPlot.o SciPlot.o medmCA.o actions.o bubbleHelp.o callbacks.o browserHelp.o channelPalette.o colorPalette.o dialogs.o display.o eventHandlers.o help.o medm.o medmArc.o medmBar.o medmByte.o medmChoiceButtons.o medmCommon.o medmComposite.o medmControl.o medmDisplay.o medmImage.o medmIndicator.o medmMenu.o medmMessageButton.o medmMeter.o medmMonitor.o medmOval.o medmPixmap.o medmPolygon.o medmPolyline.o medmRectangle.o medmRelatedDisplay.o medmShellCommand.o medmStripChart.o medmText.o medmTextEntry.o medmTextUpdate.o medmValuator.o medmWheelSwitch.o medmWidget.o objectPalette.o productDescriptionShell.o resourcePalette.o updateMonitors.o updateTask.o utils.o xgif.o   -lANLwidgets -lPrintUtils -lca -lCom -lXm -lXt -lXmu -lX11 -lXext
/usr/bin/ld: cannot find -lXmu: No such file or directory
collect2: error: ld returned 1 exit status
make[2]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_BUILD:231: medm] Error 1
make[2]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm/O.linux-x86_64'
make[1]: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/rong/EPICS/extensions/src/medm/medm'
make: *** [/home/rong/EPICS/epics-base-R7.0.7/configure/RULES_DIRS:85: medm.install] Error 2
Thank you in advance.
Rong
linux medm installation error: cannot find -lXmu Rong Huang via Tech-talk
Prev: linux medm installation error: cannot find -lXmu Rong Huang via Tech-talk
Next: Re: Re: How do I setEPICS opc UA security Settings? Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Next: #define usage in Sequencer Hyung Jin Kim via Tech-talk
ANJ, 02 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
