1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: [External] Re: Links between bob files in different support modules
From: "Cobb, Tom \(DLSLtd,RAL,LSCI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 5 Apr 2023 13:02:08 +0000
Thanks everyone for the suggestions. I like Kay's idea of a directory of softlinks, but I also like the idea of replicating a search path at the IOC level. Using Kay's example I think I will have a go with the following:
IOC1/motor_overview.bob -> /path/to/motor/v1/motorApp/opi/bob/motor_overview.bob
IOC1/motor_detail.bob -> /path/to/motor/v1/motorApp/opi/bob/motor_detail.bob
IOC1/ls_overview.bob -> /path/to/lakeshore/v1/lakeshoreApp/opi/bob/ls_overview.bob
IOC1/ls_detail.bob -> /path/to/lakeshore/v1/lakeshoreApp/opi/bob/ls_detail.bob
IOC1/ioc1_overview.bob
IOC2/motor_overview.bob -> /path/to/motor/v2/motorApp/opi/bob/motor_overview.bob
IOC2/motor_detail.bob -> /path/to/motor/v2/motorApp/opi/bob/motor_detail.bob
IOC2/ioc2_overview.bob
bl_overview.bob
This means that if motor_detail.bob​ wanted to link to ls_detail.bob​, it would have an action button that opened ls_detail.bob​. It would then pick up the version of lakeshore that was defined for that IOC. If iocx_overview.bob​ wanted to open motor_detail.bob​ it would have an action button to motor_detail.bob​ and if bl_overview.bob​ wanted to open ioc1_overview.bob​ it would have an action button to IOC1/ioc1_overview.bob​.
Tom
Sent: 28 March 2023 18:02
To: Cobb, Tom (DLSLtd,RAL,LSCI) <tom.cobb at diamond.ac.uk>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Tom
I was thinking:  in your environment before calling the phoebus startup command from your shell
I use a script to startup our phoebus so I could put such things there as well,
export BSUPPORT=../../../BSupport/BSupportApp/op/bob
of course this only works if your running bob file is at the right spot relative to the targeted bob file .
-ps
-ps
On Tue, Mar 28, 2023 at 10:17 AM Cobb, Tom (DLSLtd,RAL,LSCI) <tom.cobb at diamond.ac.uk> wrote:
Hi Paul,
Interesting, I hadn't thought of using macros. So, I guess these macros would be how to get to the bob files of a particular module from a common root. So from a bob file in the root, you could refer to $(ASUPPORT)/A_details.bob​. However, I still can't work out how you could make a relative link from a screen in ASupport to a screen in BSupport...
Tom
Sent: 28 March 2023 13:30
Subject: Re: Links between bob files in different support modules
Tom
To simplify the syntax in the bob files You could use a macro based on a  (relative) path definition from your phoebus environment.
Regards
-ps
On Tue, Mar 28, 2023 at 06:02 Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi all,
We are looking at how to structure bob files within our support modules, especially how to link between support modules. For example, imagine we have a bob file ASupport/ASupportApp/op/bob/A_details.bob​ and we want to link to BSupport/BSupportApp/op/bob/B_details.bob​. As phoebus doesn't support a search path (for good reasons) we would need to supply an absolute or relative path to B_details.bob​ in A_details.bob​. My instinct is to use relative paths, so the directory tree can be served over http at runtime, but this means a link to ../../../BSupport/BSupportApp/op/bob/B_details.bob​ in A_details.bob​ which mandates that the two support modules be checked out next to each other.
Has anyone else had to link between bob files in two different support modules? If so, how have you done it?
Tom
Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: Links between bob files in different support modules Paul Sichta via Tech-talk
Re: Links between bob files in different support modules Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Re: [External] Re: Links between bob files in different support modules Paul Sichta via Tech-talk
Prev: Re: USPAS (was: RE: [External] Re: Probe plug-in for the Probe panel?) Kasemir, Kay via Tech-talk
Next: Re: Probe plug-in for the Probe panel? Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: [External] Re: Links between bob files in different support modules Paul Sichta via Tech-talk
Next: Re: Links between bob files in different support modules Kasemir, Kay via Tech-talk
ANJ, 05 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
