Today, I would like to mention an interesting issue that manifest itself in camonitor (with any PV, no matter the server) as follows:
CA.Client.Exception...............................................
Warning: "Identical process variable names on multiple servers"
Context: "Channel: "SR-DI-DCCT-01:SIGNAL.NAME", Connecting to: cs03r-cs-gate-01.cs.diamond.ac.uk:5064, Ignored: 0.0.0.1:5"
Source File: ../cac.cpp line 1308
The problem has been identified and it is caused by a series of unfortunate events described below:
- Some IOC was
mistakenly started with EPICS_CA_SERVER_PORT=5065
- That IOC contains CA links that will try and retry (forever) to send CA_PROTO_SEARCH request messages (using port 5065)
- Meanwhile, in the same network, there is one or many CA clients to random PVs, the caRepeater will forward the CA_PROTO_SEARCH request message to every CA client (mistakenly thinking that it is a beacon message)
- The CA client mistakenly parses the CA_PROTO_SEARCH request thinking that is a
CA_PROTO_SEARCH response (given that channel access doesn't have any flag to indicate if it's a request or a response)
- The CA client will check the last field of the header of CA_PROTO_SEARCH message which in both cases (reply and response) correspond to the Search ID... this means the message is most of the times discarded because
of a non-matching search ID, but because the faulty IOC is sending CA_PROTO_SEARCH requests continuously (starting with low values of search ID), it eventually clashes with the Search ID that that client used.
- The CA client will mistakenly parse the fields server port and IP which results in the message with invalid IP shown above
Now, I would like to suggest a solution (which I think is simpler than the alternatives)... according to the CA spec, the data type field of the CA_PROTO_SEARCH response should be 0, while in the response, the same offset is the
version and shouldn't be 0, therefore, we can use that for filtering the CA_PROTO_SEARCH request. My proposal is reflected in the following patch (which hasn't been tested but should work):
diff --git a/modules/ca/src/client/udpiiu.cpp b/modules/ca/src/client/udpiiu.cpp
index c6ffb6def..27f91f5ad 100644
--- a/modules/ca/src/client/udpiiu.cpp
+++ b/modules/ca/src/client/udpiiu.cpp
@@ -680,6 +680,13 @@ bool udpiiu :: searchRespAction (
return true;
+ * CA requires this field to be 0 in the search response
+ if (msg.m_dataType != 0) {
+ return true;
* Starting with CA V4.1 the minor version number
* is appended to the end of each UDP search reply.
I hope you also find this issue interesting,
Kind Regards,
Emilio
