1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: Re: Search all PV available
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>, CAOUEN Loic <loic.caouen at cea.fr>
Date: Thu, 20 Apr 2023 13:55:39 +0000
In short, no.
First note that there's a difference between records and PVs.
In principle, every field of every record can be a PV.
For an analog input record "X", you can get a DBR_CTRL_DOUBLE type of channel that basically provides the content of VAL, TIME, EGU, PREC, ...
You can also create a DBR_STRING channel for "X.EGU" and so on.
In most cases you use just the record name as a channel name, but for a motor record, "X.RBV" is a very useful channel.
So the exact number of channels isn't really well defined, but what you're probably looking for is a list of record names. Then again, no, out of the box that's not available on the network.
Just like you can't get a list of all web pages from a web server.
For web pages, google tries to build a list of web pages in various ways.
> .. available on an IP address ?
In practice, the use case it typically not finding a list of records for a running IOC.
If you have the IP address, you can usually somehow get to the IOC and type "dbl".
The task at hand is usually that PV "X" is unresolved and you need to figure out where that record was supposed to be, which IOC happens to be down right now.
So for that some offline database which gets populated when IOCs start but can then tell you later where a record was last seen is better.
For IOCs, the Channel Finder and 'recsync' are one way to build it.
Another approach is adding something like "dbl >list_of_records" to the end of each IOC startup script, and then have some home-built service tool collect those lists of records per IOC.
-Kay
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of CAOUEN Loic via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, April 20, 2023 9:18 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: [EXTERNAL] Search all PV available
Hello,
Is there a way to find all the ChannelAccess PV available on an IP address ?
I’ve had a look to Channel Finder https://github.com/ChannelFinder but it looks like a search engine (search the PV info put in the engine database).
Is there a tool in epics base to do that ?
Loïc
Search all PV available CAOUEN Loic via Tech-talk
Prev: Search all PV available CAOUEN Loic via Tech-talk
Next: Including a blinking LED in my Phoebus CSS GUI Meddage, Varuna via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: Search all PV available Blomley, Edmund (IBPT) via Tech-talk
ANJ, 20 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
