1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Problem using ADPICam driver
To: tech-talk tech-talk <[email protected]>, Jörn Dreyer <[email protected]>
Date: Thu, 27 Apr 2023 14:07:47 +0000
Hi Jörn,
I have not used ADPICam before, so I am not sure what the problem is. I am using lots of PI cameras on Windows with ADLightField.
> With another software that I have the camera works perfectly delivering images.
What is the other software that is working?  Is it running on the same Linux machine?
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Thursday, April 27, 2023 7:00 AM
Subject: Problem using ADPICam driver
Hello,
I have a problem using a PrincetonInstruments PIXIS camera with ADPICam. My
IOC hangs in the Line PICamConfig("PICAM", 20, 0x5000000, 2, 0x5000000).
The out put of strrace shows:
openat(AT_FDCWD, "/dev/bus/usb/001/004", O_RDWR|O_CLOEXEC) = 23
ioctl(23, USBDEVFS_GET_CAPABILITIES, 0x5621d1320e8c) = 0
ioctl(23, USBDEVFS_CLAIMINTERFACE, 0x7ffd05254f24) = 0
timerfd_settime(13, TFD_TIMER_ABSTIME, {it_interval={tv_sec=0, tv_nsec=0},
it_value={tv_sec=8721277, tv_nsec=456792680}}, NULL) = 0
ioctl(23, USBDEVFS_SUBMITURB, 0x5621d130e4e0) = 0
ioctl(23, USBDEVFS_SUBMITURB, 0x5621d13287e0) = 0
read(12, "\1\0\0\0\0\0\0\0", 8)         = 8
poll([{fd=12, events=POLLIN}, {fd=13, events=POLLIN}, {fd=23,
events=POLLOUT}], 3, 60000) = 1 ([{fd=23, revents=POLLOUT}])
ioctl(23, USBDEVFS_REAPURBNDELAY, 0x7ffd05254bb0) = 0
ioctl(23, USBDEVFS_REAPURBNDELAY, 0x7ffd05254bb0) = -1 EAGAIN (Resource
temporarily unavailable)
That tells me, that it finds the camera but has somehow problems to
communicate with it. Looking with the debugger where it hags, reveals that
this happens already in the call to Picam_InitializeLibrary().
I have setup an udev rules file with the following content:
ATTRS{idVendor}=="0bd7", ATTRS{idProduct}=="a026", MODE="0666",
GROUP="plugdev"
When I plugin the camera it gets detected by the system::
[8720825.614808] usb 1-10: config 1 interface 0 altsetting 0 bulk endpoint
0x81 has invalid maxpacket 64
[8720825.614811] usb 1-10: config 1 interface 0 altsetting 0 bulk endpoint 0x1
[8720825.614978] usb 1-10: config 1 interface 0 altsetting 0 bulk endpoint
[8720825.614980] usb 1-10: config 1 interface 0 altsetting 0 bulk endpoint 0x1
[8720825.615137] usb 1-10: New USB device found, idVendor=0bd7,
idProduct=a026, bcdDevice= 0.00
[8720825.615139] usb 1-10: New USB device strings: Mfr=1, Product=2,
SerialNumber=0
[8720825.615140] usb 1-10: Product: PIXIS V3.6
[8720825.615141] usb 1-10: Manufacturer: Princeton Instruments
I tried with different USB ports, optical extender etc. With another software
that I have the camera works perfectly delivering images. But EPICS somehow
has a problem with the device. I am using areaDetector R3-12-1.
Any ideas whet could be causing this? It looks like some accessrights are not
set properly, but I have no clue where.
Regards
Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Helmholtz - Zentrum Dresden - Rossendorf
Re: Problem using ADPICam driver Jörn Dreyer via Tech-talk
Prev: Problem using ADPICam driver Jörn Dreyer via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Problem using ADPICam driver Jörn Dreyer via Tech-talk
