1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: EPICS 3.15.9 build system weird behaviour upon missing g++
From: "Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: [email protected]
Date: Thu, 27 Apr 2023 22:33:11 +0700 (+07)
Andrew, thanks for your reply!
It does shed some light on what's going on, but not everything is clear.
On Wed, 26 Apr 2023, Johnson, Andrew N. wrote:
If you look carefully at the compiler commands there that fail they include flags for generating dependency files (-M?), they are not actually compiling the code yet. I don?t have the rules in front of me right now but our build rules evidently don?t want to fail a build if the compiler isn?t able to generate some of the .d files, for various reasons. Those .d files are actually Makefiles and get included so are created in the first pass of the build. GNU-make finds that it has rules to rebuild makefiles so it runs them before attempting to run the actual compile, and that?s where the build actually fails. This is fairly complex, but there is documentation about what GNU make does which is worth reading if you really want to understand it.
Unfortunately, the build system ignores errors from not only g++ runs for depencency generation (those with -MM -MF), but ALL of them, including .cc to .o compilation (those with "-c").
It is visible in my build logs excerpts
(https://epics.anl.gov/tech-talk/2023/msg00595.php): the last command, before freeList.html, is *compilation* of epicsTempFile.cpp. But instead of immediately stopping, the build process continues and stops a bit later because of absent epicsTempFile.o, which should have been made by g++.
Is there any document describing how EPICS build system is configured to ignore *some* errors (curiously, without a use of ".IGNORE:", "--ignore" or "-" before commands)?
P.S. I'm trying to investigate this problem not because of "missing g++" (which is obviously a non-issue), but to understand how the EPICS build system works. Which, in turn, is needed to solve another class of problems: when something goes wrong during build, e.g. "genApps" SIGSEGVs on some architectures (due to a buggy gddUtils.h), the error isn't shown "as is" immediately but the build process continues and only the "induced" error due to a missing file is shown later.
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
Prev: Re: Problem using ADPICam driver Mark Rivers via Tech-talk
Next: RE: OMS MAXnet motorOmsAsyn module’s autosave Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
