1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: EPICS 3.15.9 build system weird behaviour upon missing g++
From: "Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected]>
To: [email protected]
Date: Wed, 26 Apr 2023 10:04:45 +0700 (+07)
Hi!
I tried to build base-3.15.9 on a system which accidentally lacked g++ compiler and encountered a weird behaviour: instead of stopping the build process upon first error, "make" continued and stopped much later due to inability to make a target:
Installing generic include file ../../../include/yajl_gen.h
Installing generic include file ../../../include/yajl_parse.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic    -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/ti
mer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
make[3]: /usr/bin/g++: No such file or directory
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE          -D_X86_64_ -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic    -m64  -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libCom/timer -
I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF warshall.d  ../../../src/libCom/yacc/warshall.c
mer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF resourceLib.d  ../../../src/libCom/cxxTemplates/resourceLib.cpp
Installing html ../../../html/./freeList/freeList.html
mkdir ../../../html/./freeList
Installing html ../../../html/./gpHash/gpHash.html
mkdir ../../../html/./gpHash
make[3]: *** No rule to make target 'epicsTempFile.o', needed by 'antelope'.  Stop.
make[3]: Leaving directory '/tmp/x/base-3.15.9/src/libCom/O.linux-x86_64'
make[2]: *** [../../configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[2]: Leaving directory '/tmp/x/base-3.15.9/src/libCom'
make[1]: *** [../configure/RULES_DIRS:85: libCom.install] Error 2
make[1]: Leaving directory '/tmp/x/base-3.15.9/src'
This can be easily reproduced via e.g. "make CCC=/NON/EXISTENT":
/NON/EXISTENT  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I../../../src/libCom/osi/compiler/gcc -I../../../src/libCom/osi/compiler/default -I. -I../../../src/libCom/osi/os/Linux -I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default -I.. -I../../../src/libCom/as -I../../../src/libCom/bucketLib -I../../../src/libCom/calc -I../../../src/libCom/cvtFast -I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates -I../../../src/libCom/dbmf -I../../../src/libCom/ellLib -I../../../src/libCom/env -I../../../src/libCom/error -I../../../src/libCom/fdmgr -I../../../src/libCom/flex -I../../../src/libCom/freeList -I../../../src/libCom/gpHash -I../../../src/libCom/iocsh -I../../../src/libCom/log -I../../../src/libCom/macLib -I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/pool -I../../../src/libCom/ring -I../../../src/libCom/taskwd -I../../../src/libC
om/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -c ../../../src/libCom/osi/os/posix/epicsTempFile.cpp
make[3]: /NON/EXISTENT: Command not found
er -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF warshall.d  ../../../src/libCom/yacc/warshall.c
om/timer -I../../../src/libCom/yacc -I../../../src/libCom/yacc -I../../../src/libCom/yajl -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include         -MM -MF resourceLib.d  ../../../src/libCom/cxxTemplates/resourceLib.cpp
make[3]: *** No rule to make target `epicsTempFile.o', needed by `antelope'.  Stop.
make[3]: Leaving directory `/tmp/x/base-3.15.9/src/libCom/O.linux-x86_64'
make[2]: *** [install.linux-x86_64] Error 2
make[2]: Leaving directory `/tmp/x/base-3.15.9/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/tmp/x/base-3.15.9/src'
make: *** [src.install] Error 2
Why does this happen? Grepping through the whole base-3.15.9/ dir doesn't show a reason: neither ".IGNORE:" special target nor "-i" or "--ignore" flags.
Is this the intended behaviour?  Shouldn't "make" stop on first error?
P.S. This is CentOS-7.3 on x86_64, but that's irrelevant, as the same happens on other distros and architectures.
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
Prev: Re: [EXTERNAL] Re: opc ua client Sinclair, John via Tech-talk
Next: Could not use autosave with motorOmsAsyn whitetiger1123 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: question about ALIAS 李姣赛 via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
