1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Could not use autosave with motorOmsAsyn
From: whitetiger1123 via Tech-talk <[email protected]>
Date: Wed, 26 Apr 2023 15:43:27 +0900
Epics Base version = R3.15.9
Maxnet firmware version =  MAXn-A000 ver:1.50, s/n:000487, FPGA:AAA4:02 BOOT:1.06 - Oregon Micro Systems
I already used motorOmsAsyn without autosave, now I want to use motorOmsAsyn with autosave.
I did autosave compile very well, but when I start ./st.cmd at motorOmsAsyn with autosave, I think it can not find autosave functions.
This is path of motorOmsAsyn: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn.
[root@localhost iocOmsAsyn]# ls
   autosave  autosave-req  cdCommands  Makefile  MAXnet.cmd  MAXnet.substitutions  MAXv.cmd  MAXv.substitutions  pid.txt  save_restore.cmd  st.cmd
[root@localhost iocOmsAsyn]# ./st.cmd
< cdCommands
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("MOTOR","/usr/local/epics/synApps_6_1/support/motor-R7-1")
epicsEnvSet("SUPPORT","/usr/local/epics/synApps_6_1/support")
epicsEnvSet("ASYN","/usr/local/epics/synApps_6_1/support/asyn-R4-36")
epicsEnvSet("SNCSEQ","/usr/local/epics/synApps_6_1/support/seq-2-2-6")
epicsEnvSet("BUSY","/usr/local/epics/synApps_6_1/support/busy-R1-7-2")
epicsEnvSet("AUTOSAVE","/usr/local/epics/synApps_6_1/support/autosave-R5-10")
epicsEnvSet("OPTICS","/usr/local/epics/synApps_6_1/support/optics-R2-13-3")
epicsEnvSet("CALC","/usr/local/epics/synApps_6_1/support/calc-R3-7-3")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
epicsEnvSet("STARUP","/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC")
epicsEnvSet("AUTOSAVE_FILE","/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn")
dbLoadDatabase("/usr/local/epics/synApps_6_1/support/motor-R7-1/dbd/omsAsynSupport.dbd")
dbLoadDatabase("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/dbd/omsAsyn.dbd")
omsAsyn_registerRecordDeviceDriver(pdbbase)
< MAXnet.cmd
# Serial
drvAsynSerialPortConfigure("MAXNET1","/dev/ttyUSB0",0,0,0)
asynSetOption("MAXNET1",0,"baud","115200")
asynSetOption("MAXNET1",0,"bits","8")
asynSetOption("MAXNET1",0,"parity","none")
asynSetOption("MAXNET1",0,"crtscts","Y")
# The IEOS depends on the firmware version
asynOctetSetInputEos("MAXNET1",0,"\n\r")
asynOctetSetInputEos("MAXNET1",0,"\n")
dbLoadTemplate("MAXnet.substitutions")
omsMAXnetConfig("MAXnet1", 10, "MAXNET1", 200, 2000, "AX LH PSO; AY LH PSO; AZ LH PSO; AT LH PSO; AU LH PSO; AV LL PSO; AR LH PSO; AS LH PSO; AW LH PSO; AK LH PSO;")
OMS Firmware Version: MAXn-A000 ver:1.50, s/n:000487, FPGA:AAA4:02 BOOT:1.06 - Oregon Micro Systems
It works well, when I do not use autosave.
But when I use autosave command, it can’t find autosave functions.
< save_restore.cmd
save_restoreSet_Debug(0)
save_restore.cmd line 5: Command save_restoreSet_Debug not found.
save_restoreSet_IncompleteSetsOk(1)
save_restore.cmd line 8: Command save_restoreSet_IncompleteSetsOk not found.
save_restoreSet_DatedBackupFiles(1)
save_restore.cmd line 10: Command save_restoreSet_DatedBackupFiles not found.
save_restoreSet_NumSeqFiles(3)
save_restore.cmd line 13: Command save_restoreSet_NumSeqFiles not found.
save_restoreSet_SeqPeriodInSeconds(300)
save_restore.cmd line 15: Command save_restoreSet_SeqPeriodInSeconds not found.
set_requestfile_path("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave-req")
save_restore.cmd line 25: Command set_requestfile_path not found.
set_savefile_path("/usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/iocBoot/iocOmsAsyn/autosave")
save_restore.cmd line 26: Command set_savefile_path not found.
set_pass0_restoreFile("auto_settings2.sav")
save_restore.cmd line 35: Command set_pass0_restoreFile not found.
set_pass1_restoreFile("auto_settings2.sav")
save_restore.cmd line 36: Command set_pass1_restoreFile not found.
# specify directories in which to to search for included request files
set_requestfile_path("(AUTOSAVEFILE)/autosave-req")
save_restore.cmd line 40: Command set_requestfile_path not found.
iocInit
Starting iocInit
## EPICS R3.15.9
## EPICS Base built Apr  7 2022
## motorUtil (allstop & alldone)
#motorUtilInit("BL:HX:EH2:CXI:")
# Autosave monitor
create_monitor_set("auto_settings2.req",60)
st.cmd line 36: Command create_monitor_set not found.
##### Autosave End ####
# Boot complete
epics> dbl
TEST:CRX
Can you help me about this error? I did lots of things to use autosave, but still can’t solve this problem
Best and Regards,
Baeg.
Prev: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: Could not use autosave with motorOmsAsyn Blomley, Edmund (IBPT) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
