1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: OMS MAXnet motorOmsAsyn module’s autosave
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: whitetiger1123 <holyeongbaeg at gmail.com>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 27 Apr 2023 15:39:53 +0000
Have you edited a configure/RELEASE* file to add AUTOSAVE?  Please send the complete output when you run “make clean” and “make” in that directory.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of whitetiger1123 via Tech-talk
Sent: Thursday, April 27, 2023 2:37 AM
To: tech-talk at aps.anl.gov
Subject: OMS MAXnet motorOmsAsyn module’s autosave
I really appreciate about your comment, OMS MAXnet motorOmsAsyn modules autosave.
I checked it, but it already added.
https://epics.anl.gov/tech-talk/2023/msg00597.php
pwd: /usr/local/epics/synApps_6_1/support/motor-R7-1/modules/motorOmsAsyn/iocs/omsAsynIOC/omsAsynApp/src
vi Makefile
# Makefile
TOP = ../..
include $(TOP)/configure/CONFIG
DBD += omsAsynSupport.dbd
DBD += $(AUTOSAVE)/dbd/asSupport.dbd
DBD += $(OPTICS)/dbd/opticsSupport.dbd
LIBRARY_IOC_DEFAULT += omsAsyn
SRCS += omsBaseAxis.cpp
SRCS += omsBaseController.cpp
SRCS += omsMAXnet.cpp
SRCS += omsMAXv.cpp
SRCS += omsMAXvEncFunc.cpp
omsAsyn_LIBS += motor
omsAsyn_LIBS += asyn
omsAsyn_LIBS += autosave
omsAsyn_LIBS += optics
omsAsyn_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
$(AUTOSAVE) => /usr/local/epics/synApps_6_1/support/autosave-R5-10
But it still show an same error. Is this problem because of autosave compile?
Sincerely,
Baeg
OMS MAXnet motorOmsAsyn module’s autosave whitetiger1123 via Tech-talk
Prev: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: OMS MAXnet motorOmsAsyn module’s autosave whitetiger1123 via Tech-talk
Next: Problem using ADPICam driver Jörn Dreyer via Tech-talk
ANJ, 27 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
