Dear All
First of all, thank you for your help. We are developing a multi-core program in Epics 7.0.4. (Scientific Linux 7.9 / kernel 3.10.0-1160.42.2.rt56.1182.el7.x86_64)
We use a function called epicsEventWaitWithTimeout(id,timeOut). We obtained the following Time Test results.
#1 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 1); > Result: 1000067us (MAX) / 1000014us (MIN)
#2 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0.0005); > Result: 550us (MAX) / 549us (MIN)
#3 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0.0001); > Result: 154us (MAX) / 112us (MIN)
#4 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0.00005); > Result: 104us (MAX) / 97us (MIN)
#5 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0.00001); > Result: 64.9us (MAX) / 60.5us (MIN)
#6 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0.000001); > Result: 56us (MAX) / 55.9us (MIN) #7 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId, 0); > Result: 54.9us (MAX) / 54.8us (MIN)
The time measurement method is as follows.
There are some questions based on the test results. Q1) The parameter, timeout, is a double type, indicating seconds. But the result is not. Something is not accurate. What could be the cause? Q2) How do I improve time accuracy? Q3) Is there any other way than using epicsEventWaitWithTimeout?
Thank you and Best Regards,
- Re: Questions about Function: epicsEventWaitWithTimeout (id, timeout) Till Straumann via Tech-talk
- Re: External: Questions about Function: epicsEventWaitWithTimeout (id, timeout) Niko Kivel via Tech-talk
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
<2023>
2025
2026
Job Opportunities: Controls Software Developers and DevOps Engineer, STFC ISIS Facility, Oxfordshire, UK Ivan Finch - STFC UKRI via Tech-talk
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
