1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: External: Questions about Function: epicsEventWaitWithTimeout (id, timeout)
To: "[email protected]" <[email protected]>, 김대영 <[email protected]>
Cc: 박상욱/수석/SnE팀 <[email protected]>, 박진용/책임/CnS팀 <[email protected]>
Date: Tue, 2 May 2023 16:01:36 +0000
Hi
To me it looks like you have a rather stable (given the small sample size) upper bound offset of 55 us. That's your baseline processing time. If you want 250 us delay, you'd need to ask for 195 us .. in this case.
As Till mentioned you have to put load on the system. Not only CPU-load, but also disk-IO and network. Common trip wires are, automount, log rotate, network manager, ... . So basically, any process that thinks of itself as being "smart". Turn them off if possible. Turn all power saving features off. The system needs to boot, assume a state and not change that state later.
To get a good hold on the performance, tests need to be run over a long time. That is days, rather than hours. You can run for a week w/o issue, then log rotate kicks in and the proverbial s**t hits the fan.
Best
Niko
From: Tech-talk <[email protected]> on behalf of 김대영 via Tech-talk <[email protected]>
Sent: Monday, May 1, 2023 11:30 PM
To: [email protected] <[email protected]>
Cc: 박진용/책임/CnS팀 <[email protected]>; 박상욱/수석/SnE팀 <[email protected]>
Subject: External: Questions about Function: epicsEventWaitWithTimeout (id, timeout)
Dear All
First of all, thank you for your help.
We are developing a multi-core program in Epics 7.0.4.
(Scientific Linux 7.9 / kernel 3.10.0-1160.42.2.rt56.1182.el7.x86_64)
We use a function called epicsEventWaitWithTimeout(id,timeOut).
We obtained the following Time Test results.
#1 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  1);
     >  Result: 1000067us (MAX) / 1000014us (MIN)
#2 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0.0005);
     >  Result: 550us (MAX) / 549us (MIN)
#3 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0.0001);
     >  Result: 154us (MAX) / 112us (MIN)
#4 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0.00005);
     >  Result: 104us (MAX) / 97us (MIN)
#5 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0.00001);
     >  Result: 64.9us (MAX) / 60.5us (MIN)
#6 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0.000001);
     >  Result: 56us (MAX) / 55.9us (MIN)
#7 epicsEventWaitWithTimeout( pSTDev->ST_RTthread.threadEventId,  0);
     >  Result: 54.9us (MAX) / 54.8us (MIN)
The time measurement method is as follows.
There are some questions based on the test results.
Q1) The parameter, timeout, is a double type, indicating seconds.
     But the result is not. Something is not accurate. What could be the cause?
Q2) How do I improve time accuracy?
Q3) Is there any other way than using epicsEventWaitWithTimeout?
Thank you and Best Regards,
Questions about Function: epicsEventWaitWithTimeout (id, timeout) 김대영 via Tech-talk
Prev: Re: Questions about Function: epicsEventWaitWithTimeout (id, timeout) Till Straumann via Tech-talk
Next: RE: Sequencer configuration file David A. Slimmer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Epics Archiver Online Status Question Manoussakis, Adamandios via Tech-talk
