1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [Ext] Re: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports)
From: Jesse Hopkins via Tech-talk <[email protected]>
Date: Thu, 4 May 2023 13:59:21 -0500
For single port applications I've used the iBoot G2+ web power switch, and it's been quite useful. They have several versions of ethernet switchable outlets (as well as TTL control/contact closure control which I also use):
The pricing doesn't seem to scale with the larger models, like the 8 port APC ones (e.g. it's not 1/8th the cost), but for cases where you really don't need more ports, or you have form factor limitations they're a nice option.
While they do have (and advertise) their web and cloud interfaces, at least some models are controllable directly over TCP. I don't have an EPICS driver for it, but it's literally just two lines of python code using the requests package to turn it on and off (and a third if you want to get the status), so I don't imagine it would be hard to write compatible EPICS code.
All the best.
- Jesse
Jesse Hopkins, PhD
Deputy Director
BioCAT, Sector 18
Advanced Photon Source
On Thu, May 4, 2023 at 12:03 PM Han Lee via Tech-talk <[email protected]> wrote:
Hi Kristi,
The APC or other vendors can support SNMP or other protocols. We use the SNMP to monitor and control each port minimally. IT security group doesn't like SNMP, by the way.
Tripplite sells 16 ports with 1U size. You can take a look at their products.
However, you must check two things.
  • Current consumption of your entire hardware connected to that PDU. This will give you the correct PDU. Note that North America has a 20% or 25% limitation of the max current of PDU. For example, PDU supports 30A, you only use 26A in North America.
  • Location of PDU, if you want to put them in the tunnel, you should consider the shielding for PDU or any side effects from radiation.
Best,
Han
On Thu, May 4, 2023 at 9:50 AM Luchini, Kristi L. via Tech-talk <[email protected]> wrote:
Hello,
We use ethernet power strips from APC that allow remote control (on/off/reboot) of each port on the power strip individually.  The standard number of ports is 8 but we also use power strips with more ports. However, I  only need one port that will be installed in up to 35 chassis (installed in the tunnel) that will allow the power cycle the hardware plugged into this port, if necessary.  I really don’t want to purchase a 8 port power strip when I only need 1 port.  If another lab uses such a device, I’d also like to download the EPICS driver, or asyn protocol file to talk to the device. I realize that many of these devices come with a web interfaces, but want to integrate this into the EPICS control system. Also  web interfaces are generally not permitted on our production systems.
Any recommendations would be appreciated.
-Kristi
Jeong Han Lee, Dr.rer.nat.
Staff Scientist and Engineer
Cell: +1 510 384 3868
Power strip with ehthernet interfacet to allow remote control -- (1-2 ports) Luchini, Kristi L. via Tech-talk
Re: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports) Han Lee via Tech-talk
Prev: Re: Power strip with ehthernet interfacet to allow remote control -- (1-2 ports) Han Lee via Tech-talk
Next: RE: Epics Archiver Online Status Question [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: SNL graph generator Henrique Silva via Tech-talk
