1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Why does libca.so depend on libreadline.so?
To: Simon Rose <[email protected]>, "Dmitry Yu. Bolkhovityanov" <[email protected]>
Date: Fri, 12 May 2023 15:06:29 +0000
  • The key is 7.0.7: even 7.0.6.1's libCom.so does have a dependency on libreadline.so, while 7.0.7 do not.
I now recall that when I built my IOCs with base 7.0.7 command line recall did not work on Centos 7.  The automatic detection of the readline support does not work with older versions of gcc.
I posted the issue to core-talk:
Thus, on the advice of Michael Davidsaver I made this edit:
diff --git a/configure/toolchain.c b/configure/toolchain.c
index 2f76b475b..da4e8bb2c 100644
--- a/configure/toolchain.c
+++ b/configure/toolchain.c
@@ -45,5 +45,5 @@ COMMANDLINE_LIBRARY ?= READLINE
 COMMANDLINE_LIBRARY ?= EPICS
 #  endif
 #else
-COMMANDLINE_LIBRARY ?= EPICS
+COMMANDLINE_LIBRARY ?= $(strip $(if $(wildcard $(if $(GNU_DIR),$(GNU_DIR)/include/readline/readline.h)), READLINE, EPICS))
 #endif
With that edit command line recall does work, and base 7.0.7 libCom.so does depend on libreadline.
This is base 7.0.7 on Centos 7.  It depends on libreadline.so.6.
corvette:local/epics-devel/base-7.0.7>ldd lib/linux-x86_64/libCom.so
        linux-vdso.so.1 =>  (0x00007ffe673d6000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f171eec5000)
        libreadline.so.6 => /lib64/libreadline.so.6 (0x00007f171ec7f000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f171ea77000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f171e873000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f171e56b000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f171e269000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f171e053000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f171dc85000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f171f355000)
        libtinfo.so.5 => /lib64/libtinfo.so.5 (0x00007f171da5b000)
This is base 7.0.7 on Centos 8.  It depends on libreadline.so.7.
Last login: Sun Apr 30 16:49:17 2023 from 164.54.160.82
[epics@viper ~]$ cd /corvette/usr/local/epics-devel/base-7.0.7
[epics@viper base-7.0.7]$ ldd lib/linux-x86_64-centos8/libCom.so
        linux-vdso.so.1 (0x00007ffc88315000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fa3a7c94000)
        libreadline.so.7 => /lib64/libreadline.so.7 (0x00007fa3a7a45000)
        librt.so.1 => /lib64/librt.so.1 (0x00007fa3a783d000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007fa3a7639000)
        libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fa3a72a4000)
        libm.so.6 => /lib64/libm.so.6 (0x00007fa3a6f22000)
        libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fa3a6d0a000)
        libc.so.6 => /lib64/libc.so.6 (0x00007fa3a6945000)
        /lib64/ld-linux-x86-64.so.2 (0x00007fa3a812a000)
        libtinfo.so.6 => /lib64/libtinfo.so.6 (0x00007fa3a6718000)
This is Ubuntu 22.  It depends on libreadline.so.8.
TahoeU18:/corvette/usr/local/epics-devel/base-7.0.7> ldd lib/linux-x86_64-ub18/libCom.so
        linux-vdso.so.1 (0x00007ffc6bbf9000)
        libreadline.so.8 => /lib/x86_64-linux-gnu/libreadline.so.8 (0x00007f2b0101d000)
        libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f2b00df3000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f2b00d0c000)
        libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f2b00cec000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f2b00ac2000)
        libtinfo.so.6 => /lib/x86_64-linux-gnu/libtinfo.so.6 (0x00007f2b00a90000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f2b0110a000)
From: Tech-talk <[email protected]> on behalf of Dmitry Yu. Bolkhovityanov via Tech-talk <[email protected]>
Sent: Friday, May 12, 2023 9:29 AM
Cc: [email protected] <[email protected]>
Hi Simon,
On Fri, 12 May 2023, Simon Rose wrote:
> Hi Dmitry -
> I do not get the same results as you. When I build various version of EPICS base (e.g. 7.0.4, 7.0.5) for linux-x86_64, libCom also depends on readline at that point. I don't think the change that Michael linked is the source of this dependency.
How Michael's patch achieves such an effect -- that's another question.  I
still don't understand the mechanism; I even did a "diff -Naurb
base-7.0.6.1 base-7.0.7" (just sources, of course) and there's nothing
regarding "readline" besides what patch does.
In short -- as I understood it -- the patch just moves the "readline
detection" from makefiles (which checked for
.../include/readline/readline.h presence) into .c-files (via
__has_include() builtin).
But how the detection method (which is orthogonal to dependence) manages
to relieve libCom.so from libreadline.so dependency -- I yet have to
fugure out.
With best regards,
Dmitry
Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Why does libca.so depend on libreadline.so? Michael Davidsaver via Tech-talk
Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Re: Why does libca.so depend on libreadline.so? Han Lee via Tech-talk
Re: Why does libca.so depend on libreadline.so? Andrew Johnson via Tech-talk
Re: Why does libca.so depend on libreadline.so? Simon Rose via Tech-talk
Prev: Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Next: Re: Why does libca.so depend on libreadline.so? Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: Why does libca.so depend on libreadline.so? Michael Davidsaver via Tech-talk
