1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: _registerRecordDeviceDriver warning
From: "David A. Slimmer via Tech-talk" <[email protected]>
Cc: "David A. Slimmer" <[email protected]>
Date: Mon, 15 May 2023 17:37:06 +0000
I’m trying to implement device support under base-7.0.5, and I’m getting the following warning when I compile:
Biascontroller_registerRecordDeviceDriver.cpp:382:62: warning: missing initializer for member 'iocshFuncDef::usage' [-Wmissing-field-initializers]
  382 |     {"Biascontroller_registerRecordDeviceDriver", 1, rrddArgs};
I looked at the Biascontroller_registerRecordDeviceDriver.cpp code, but it looks identical to the code generated for another project using device support built with an earlier version of EPICS base (R3.15 I think).
Any ideas where I might look to track this down?
Dave
Re: _registerRecordDeviceDriver warning Michael Davidsaver via Tech-talk
Prev: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Florian Feldbauer via Tech-talk
Next: Re: _registerRecordDeviceDriver warning Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Zimoch Dirk via Tech-talk
