1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer.
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 23 May 2023 12:06:14 +0000
Hi Andrew,
As you experience a loss of communication with the IOC, I think something goes
severely wrong on your IOC. A normal timeout should not cause this. On the other
hand, a network communication problem can of course cause the timeout.
Do you have any error messages from the IOC shell?
Have you checked if some thread has crashed (probably while holding a
semaphore)?
Is the IOC actually still running after such a fault or has it crashed
completely?
Or maybe one thread uses up all CPU cycles in some tight loop? (How many cores
does your container use? Only one?) Have you checked the CPU usage with
top/htop?
I never used containers to run IOCs. Thus, I don't know the peculiarities of
such a setup. We run several dozen IOCs on one Linux system, which itself is a
VmWare instance on a sever cluster with several dozen others. Never had any
problems (i.e. bugs) that I could not reproduce on a single physical host as
well.
Dirk
On Fri, 2023-05-12 at 18:06 +0000, Wang, Andrew via Tech-talk wrote:
> Hi all,
> I have created multiple IOCs for the project in which I am involved. They are all running in their own Docker container in a host computer running Ubuntu 20.04. In each Docker container, the following EPICs and support module versions are used.
> EPICS: 7.0.4
> StreamDevice: 2.8.15
> Asyn: 4.41
> In one of the IOCs, I have a SSEQ record that is used to push a scalar value to multiple records that set four parameters for the target instrument. There is an instance where streamDevice is unable to push the value to the second parameter, causing the protocol to abort. Then, a few minutes later, my colleagues and I have observed that no records from the IOC in question can be accessed through Channel Access. This is the error message that we receive.
> Read operation timed out: some PV data was not read.
> <RECORD_NAME> 0
> CA.Client.Exception……………………………………………………..
> Warning: “Virtual circuit disconnect”
> Context: “op=0, channel=<RECORD_NAME>, type=DBR_TIME_DOUBLE, count=1, ctx=”<IP ADDRESS:PORT>”
> Source File: ../getCopy.cpp line 91
> Current Time: <TIME>
> This also meant that I was unable to check the STAT field to see what the cause of the abortion was.
> Thank you and I look forward to hearing back from everyone.
> Andy
> Purple ribbon awareness
When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Wang, Andrew via Tech-talk
Prev: Re: makefile compilation question NICOLE Remi via Tech-talk
Next: Re:RE: no bin file lynn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: When I use an IOC in a container, streamDevice occasionally reports that protocol has been aborted, which causes the records in the IOC to become inaccessible from the host computer. Knap, Giles (DLSLtd,RAL,LSCI) via Tech-talk
Next: _registerRecordDeviceDriver warning David A. Slimmer via Tech-talk
