1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Optional record alias
Date: Sun, 11 Jun 2023 17:48:57 +0000
Folks,
This is my first time trying to use a record alias.
I would like to have a database file that looks like this:
record(bi, "$(P)$(R)")
    field(DESC, "$(DESC=)")
    field(DTYP, "asynUInt32Digital")
    field(INP,  "@asynMask($(PORT),$(ADDR),$(MASK))DIGITAL_INPUT")
    field(ZNAM, "$(ZNAM=Low)")
    field(ZSV,  "$(ZSV=NO_ALARM)")
    field(ONAM, "$(_ONAM_=High)")
    field(OSV,  "$(OSV=NO_ALARM)")
    field(SCAN, "I/O Intr")
    alias(      "$(ALIAS=)")
The DESC macro defaults to an empty string, which is works fine.  I would also like to have the ALIAS macro be optional, so that one can optionally define a record alias.  This does not work, it leads to this error when loading the database.
dbLoadRecords: failed to load '$(MEASCOMP)/measCompApp/Db/measCompBinaryIn.template'
Error: Error: Record/Alias name can't be empty
at or before ')' in file "/corvette/home/epics/support/measComp-4-1/measCompApp/Db/measCompBinaryIn.template" line 11
Error: syntax error
Is it possible to have an optional ALIAS?
Re: Optional record alias Shen, Guobao via Tech-talk
RE: Optional record alias Pearson, Matthew via Tech-talk
Prev: Re: Phoebus/CS-Studio widget question Kasemir, Kay via Tech-talk
Next: Re: Optional record alias Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
