1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: Optional record alias
From: "Pearson, Matthew via Tech-talk" <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 12 Jun 2023 14:05:08 +0000
Hi Mark,
This might be a (slightly ugly) work around:
record(bi, “$(P)$(R)”)
$(USE_ALIAS=#) alias(“$(ALIAS)”)
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: Sunday, June 11, 2023 1:49 PM
To: tech-talk at aps.anl.gov
Subject: [EXTERNAL] Optional record alias
Folks,
This is my first time trying to use a record alias.
I would like to have a database file that looks like this:
record(bi, "$(P)$(R)")
    field(DESC, "$(DESC=)")
    field(DTYP, "asynUInt32Digital")
    field(INP,  "@asynMask($(PORT),$(ADDR),$(MASK))DIGITAL_INPUT")
    field(ZNAM, "$(ZNAM=Low)")
    field(ZSV,  "$(ZSV=NO_ALARM)")
    field(ONAM, "$(_ONAM_=High)")
    field(OSV,  "$(OSV=NO_ALARM)")
    field(SCAN, "I/O Intr")
    alias(      "$(ALIAS=)")
The DESC macro defaults to an empty string, which is works fine.  I would also like to have the ALIAS macro be optional, so that one can optionally define a record alias.  This does not work, it leads to this error when loading the database.
dbLoadRecords: failed to load '$(MEASCOMP)/measCompApp/Db/measCompBinaryIn.template'
Error: Error: Record/Alias name can't be empty
at or before ')' in file "/corvette/home/epics/support/measComp-4-1/measCompApp/Db/measCompBinaryIn.template" line 11
Error: syntax error
Is it possible to have an optional ALIAS?
Re: Optional record alias Ralph Lange via Tech-talk
Optional record alias Mark Rivers via Tech-talk
Prev: Re: Optional record alias Ralph Lange via Tech-talk
Next: Re: PVA Gateway SegFault when pvcall (or eget) is used as a client Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Next: Re: Optional record alias Ralph Lange via Tech-talk
ANJ, 12 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
