Hi Mark,
I am indeed working on this, but I’ve run into an issue I don’t quite understand.
In the actual codec bit of
processCallbacks, the call to
avcodec_encode_video2()
is deprecated in favor of the decoupled send/receive
avcodec_send_frame(AVFrame*)/avcodec_receive_packet(AVPacket*)(Relevant diff below). So my intent is to do the following:
1.
Allocate block of memory for encoded frame using NDArrayPool
2.
Allocate an ffmpeg packet using ffmpeg
3.
Point ffmpeg packet data to the NDArrayPool allocated memory
4.
Send raw frame (scPicture) to the encoder for encoding w/avcodec_send_frame
5.
Pull encoded frame from encoder w/avcodec_receive_packet
6.
Encoded data ends up in this->jpeg
But, when I run this, there is no data returned from the server. If I instead maintain two blocks of memory, one maintained by ffmpeg’s memory pool and the other with AreaDetector, then memcpy
the relevant data from ffmpeg to AD, everything works fine. However, I’d prefer if I can just pass around pointers to the same data.
if (this->jpeg) {
this->jpeg->release();
- /* Convert it to a jpeg */
- this->jpeg = this->pNDArrayPool->alloc(1, &size, NDInt8, 0, NULL);
- AVPacket pkt;
- int got_output;
- av_init_packet(&pkt);
- pkt.data = "" // packet data will be allocated by the encoder
- pkt.size = c->width * c->height;
+ /* Convert it to a jpeg */
+ this->jpeg = this->pNDArrayPool->alloc(1, &size, NDInt8, 0, NULL);
+ //this->jpeg->reserve();
+ AVPacket* pkt = av_packet_alloc();
+ pkt->data = "">
+ pkt->size = c->width*c->height;
+ //pkt->buf = av_buffer_alloc(c->coded_width*c->coded_height);
// needed to stop a stream of "AVFrame.format is not set" etc. messages
scPicture->format = c->pix_fmt;
scPicture->width = c->width;
scPicture->height = c->height;
- if (avcodec_encode_video2(c, &pkt, scPicture, &got_output)) {
+ int sts;
+ sts = avcodec_send_frame(c, scPicture);
+ char err[64];
+ if(sts) {
+ av_strerror(sts, err, 64*sizeof(char));
asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
- "%s:%s: Encoding jpeg failed\n",
- driverName, functionName);
- got_output = 0; // got_output is undefined on error, so explicitly set it for use later
+ "%s%s: Encoding jpeg failed - %d - %s\n",
+ driverName, functionName, sts, err);
- if (got_output) {
- this->jpeg->dims[0].size = pkt.size;
- av_packet_unref(&pkt);
+ sts = avcodec_receive_packet(c,pkt);
+ if (sts){
+ asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
+ "%s:%s: Recv packet failed - %d - %s\n",
+ this->jpeg->dims[0].size = pkt->size;
+ //memcpy(this->jpeg->pData, pkt->data, pkt->size);
//printf("Frame! Size: %d\n", this->jpeg->dims[0].size);
/* signal fresh_frame to output plugin and unlock mutex */
for (int i=0; i<config.server_maxconn; i++) {
pthread_cond_signal(&(this->cond[i]));
pthread_mutex_unlock(&this->mutex);
+ av_packet_free(&pkt);
/* We must enter the loop and exit with the mutex locked */
this->lock();
/* Update the parameters. */
callParamCallbacks(0, 0);
// gettimeofday(&end, NULL);
Sent: Monday, June 5, 2023 11:35 AM
To: Daykin, Evan <[email protected]>; [email protected]
Subject: RE: AreaDetector ADFFmpeg with FFmpeg 5.1
[EXTERNAL] This email originated from outside of FRIB
I don’t know of any ongoing work on this, so it would be great if you could do it.
On Behalf Of Daykin, Evan via Tech-talk
Sent: Monday, June 5, 2023 10:15 AM
To: [email protected]
Subject: AreaDetector ADFFmpeg with FFmpeg 5.1
Hi tech-talk,
We are in the process of updating our systems to Debian Bookworm. The currently available FFmpeg toolchain packages for Bookworm are on version 5.1. Are there any plans to update the ADFFmpeg plugin to support
this? I’m currently trying to update our fork of the plugin, but I’m running into some hard-to-find runtime errors that I’m sure are some combination of my unfamiliarity with the new API, and the fact that I’m using the pre-built FFmpeg library without debug
symbols. If there isn’t yet an existing effort to do this, I’m happy to start.
-Evan
Evan Daykin
Controls Engineer
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824, USA
Tel. 517-908-7678
Email:
[email protected]
