1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Is it possible to know if current field is the last node of parent struct in PVXS
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Wang, Lin" <[email protected]>
Cc: [email protected]
Date: Mon, 12 Jun 2023 08:05:22 -0700
On 6/8/23 06:53, Wang, Lin via Tech-talk wrote:
Dear all,
In PVXS, when iterating over the tree structure of pvxs::Value with the approach similar to top() method in the following link,
_https://github.com/mdavidsaver/pvxs/blob/master/src/datafmt.cpp_
is it possible to know if the current field is the last node of the parent struct with pvxs::impl::FieldDesc or pvxs::impl::FieldStorage?
For example, I am wondering how to check "message" field is the last node of struct "alarm_t" when iterating.
struct "alarm_t" {
     int32_t severity = 2
     int32_t status = 1
     string message = "HIHI"
} alarm
The interface for iterating through the fields of a structure in brief is:
Value top(...); // some TypeCode::Structure
for(Value child : top.ichildren()) { ... }
Which is shorthand for something equivalent to:
    Value::IChildren range(top.ichildren());
    for(Value::IChildren::iterator cur(range.begin()), end(range.end()); cur!=end; ++cur) { Value child(*cur); ... }
cf. https://en.cppreference.com/w/cpp/language/range-for
One way to accomplish what you are asking with c++ iterators generally would be to track
both the "current" and "next" items.
    for(Value::IChildren::iterator end(range.end()), next(range.begin()), cur(next!=end ? next++ : end);
        cur!=end;
        cur=next, next!=end ? ++next : end
    ) { if(next==end) printf("last!\n"); }
Also, this is the same pattern could be used to eg. allow safe removal of 'cur' while iterating
an std::list.
You may come across other variations on this pattern, some using a while loop
instead.  This is ~equivalent functionally, and imo. ~equally ugly.
    Value::IChildren::iterator end(range.end()), next(range.begin());
    while(next!=end) {
        Value::IChildren::iterator cur=next++;
Is it possible to know if current field is the last node of parent struct in PVXS Wang, Lin via Tech-talk
Prev: RE: AreaDetector ADFFmpeg with FFmpeg 5.1 Daykin, Evan via Tech-talk
Next: Re: Optional record alias Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Is it possible to know if current field is the last node of parent struct in PVXS Wang, Lin via Tech-talk
Next: PVA Gateway SegFault when pvcall (or eget) is used as a client Murray, Doug via Tech-talk
