1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Trying to install EPICS on CentOS 7
To: "[email protected]" <[email protected]>, Brandon Gunn <[email protected]>
Date: Tue, 13 Jun 2023 23:37:09 +0000
Hi Brandon,
  • Has anyone had any luck installing EPICS on CentOS 7?
Yes, I have been using EPICS on Centos 7 for many years.  I am currently using it on Centos 6, Centos 7, Centos 8 Stream, and Centos 9 Stream.
  • When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.".
  • I'm guessing this is because it isn't installed correctly.
I think it is unlikely that the problem is with the installation.
  • Is it possible that the install is okay and there is a configuration issue preventing the caget from talking to the EPICS server?
Yes, that is more likely.  Please send the output of the following in the console window running caget:
printenv | grep EPICS
And send the output of the following at the IOC prompt on the EPICS server:
epicsPrtEnvParams
From: Tech-talk <[email protected]> on behalf of Brandon Gunn via Tech-talk <[email protected]>
Sent: Tuesday, June 13, 2023 6:27 PM
To: [email protected] <[email protected]>
Subject: Trying to install EPICS on CentOS 7
Hello,
Has anyone had any luck installing EPICS on CentOS 7? Of the required packages for CentOS 8, I can install all but one (gcc-toolset-8-make) and there is no powertools for config-manager. It throws some errors but ultimately looks like it installs, but the basic tutorial does not work. When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.". I'm guessing this is because it isn't installed correctly. Is it possible that the install is okay and there is a configuration issue preventing the caget from talking to the EPICS server?
Thank you,
Brandon
Re: Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
Prev: Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
Next: Re: Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
