1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: Trying to install EPICS on CentOS 7
From: Brandon Gunn via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 14 Jun 2023 12:59:32 -0700
It was the firewall! Adding rules resolved the issue completely, thank you very much for the help!!
Thank you,
Brandon
On Tue, Jun 13, 2023 at 8:00 PM Torsten Bögershausen <[email protected]> wrote:
Hej Brandon,
I don't have a fresh installation of Centos 7 at hand.
But I suspect that you are suffering from the firewall,
which, unless I am wrong, does not allow channel access (search requests) by default.
You can either switch off the firewall completely for a first test.
Or look further here:
https://epics.anl.gov/tech-talk/2020/msg00439.php
https://epics.anl.gov/tech-talk/2022/msg00864.php
/Torsten
PS: Timo and core-group: Is this something for the Documentathon to be picked up ?
From: Tech-talk <[email protected]> on behalf of Brandon Gunn via Tech-talk <[email protected]>
Reply to: Brandon Gunn <[email protected]>
Date: Wednesday, 14 June 2023 at 01:28
Subject: Trying to install EPICS on CentOS 7
Hello,
Has anyone had any luck installing EPICS on CentOS 7? Of the required packages for CentOS 8, I can install all but one (gcc-toolset-8-make) and there is no powertools for config-manager. It throws some errors but ultimately looks like it installs, but the basic tutorial does not work. When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.". I'm guessing this is because it isn't installed correctly. Is it possible that the install is okay and there is a configuration issue preventing the caget from talking to the EPICS server?
Thank you,
Brandon
Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
Re: Trying to install EPICS on CentOS 7 Torsten Bögershausen via Tech-talk
Prev: Re: caget from win failed when xspress3 Yin, Zhijian via Tech-talk
Next: Issue installing asyn on CentOS 7 Brandon Gunn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Re: Trying to install EPICS on CentOS 7 Torsten Bögershausen via Tech-talk
Next: node-epics-pva: A pvAccess client wrapper for Node.js Wang, Lin via Tech-talk
