Hej Brandon,
I don't have a fresh installation of Centos 7 at hand.
But I suspect that you are suffering from the firewall,
which, unless I am wrong, does not allow channel access (search requests) by default.
You can either switch off the firewall completely for a first test.
Or look further here:
https://epics.anl.gov/tech-talk/2020/msg00439.php
https://epics.anl.gov/tech-talk/2022/msg00864.php
/Torsten
PS: Timo and core-group: Is this something for the
Documentathon to be picked up ?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Brandon Gunn via Tech-talk <tech-talk at aps.anl.gov>
Reply to: Brandon Gunn <bgunn at ucsd.edu>
Date: Wednesday, 14 June 2023 at 01:28
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: Trying to install EPICS on CentOS 7
Hello,
Has anyone had any luck installing EPICS on CentOS 7? Of the required packages for CentOS 8, I can install all but one (gcc-toolset-8-make) and there is no powertools for config-manager. It throws some errors but ultimately looks like it
installs, but the basic tutorial does not work. When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.". I'm guessing this is because it isn't installed correctly. Is it possible that the install
is okay and there is a configuration issue preventing the caget from talking to the EPICS server?
