Please also send the output of epicsPrtEnvParams and dbl at the iocsh prompt.
Sent from my iPhone
Hi Mark,
Thank you for the speedy response! Glad to hear it is probably not the installation. Here is the requested output:
$ printenv | grep EPICS
EPICS_BASE=/home/specadm/EPICS/epics-base
PATH=/home/specadm/EPICS/epics-base/bin/linux-x86_64:/usr/bin:/usr/lib64/qt-3.3/bin:/home/specadm/perl5/bin:/usr/condabin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/home/specadm/.local/bin:/home/specadm/bin
EPICS_HOST_ARCH=linux-x86_64
Thank you,
Brandon
Hi Brandon,
Has anyone had any luck installing EPICS on CentOS 7?
Yes, I have been using EPICS on Centos 7 for many years. I am currently using it on Centos 6, Centos 7,
Centos 8 Stream, and Centos 9 Stream.
When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.".
I'm guessing this is because it isn't installed correctly.
I think it is unlikely that the problem is with the installation.
Is it possible that the install is okay and there is a configuration issue preventing the caget from talking to the EPICS server?
Yes, that is more likely. Please send the output of the following in the console window running caget:
And send the output of the following at the IOC prompt on the EPICS server:
epicsPrtEnvParams
Hello,
Has anyone had any luck installing EPICS on CentOS 7? Of the required packages for CentOS 8, I can install all but one (gcc-toolset-8-make) and there is no powertools for config-manager. It throws some errors but ultimately looks like it installs, but
the basic tutorial does not work. When I try to "caget temperature:water", it responds with "Channel connect timed out: 'temperature:water' not found.". I'm guessing this is because it isn't installed correctly. Is it possible that the install is okay and
Thank you,
Brandon
- Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
- Re: Trying to install EPICS on CentOS 7 Mark Rivers via Tech-talk
- Re: Trying to install EPICS on CentOS 7 Brandon Gunn via Tech-talk
Re: Trying to install EPICS on CentOS 7 Torsten Bögershausen via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
