1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Subject: RE: cross-compiling v7.0.7
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Pierrick M Hanlet <hanlet at fnal.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 15 Jun 2023 15:16:25 +0000
Hi Pierrick,
I am cross-compiling with base 7.0.7 (actually master on May 18) and it works fine for me cross-compiling for vxWorks-ppc32.  I just made these changes to configure/CONFIG_SITE:
diff --git a/configure/CONFIG_SITE b/configure/CONFIG_SITE
index 03ec6d1..12f5ab1 100644
--- a/configure/CONFIG_SITE
+++ b/configure/CONFIG_SITE
@@ -96,14 +96,14 @@
 # Which target architectures to cross-compile for.
 #  Definitions in configure/os/CONFIG_SITE.<host>.Common
 #  may override this setting.
-CROSS_COMPILER_TARGET_ARCHS=
+CROSS_COMPILER_TARGET_ARCHS=vxWorks-ppc32
 # If only some of your host architectures can compile the
 #  above CROSS_COMPILER_TARGET_ARCHS specify those host
 #  architectures here.  If the combination is complicated,
 #  set CROSS_COMPILER_TARGET_ARCHS in the appropriate
 #  configure/os/CONFIG_SITE.<host>.Common files instead.
-CROSS_COMPILER_HOST_ARCHS=
+CROSS_COMPILER_HOST_ARCHS=linux-x86_64
 #  The 'runtests', 'tapfiles' and 'junitfiles' make targets normally only run
 #  self-tests for the EPICS_HOST_ARCH architecture. If the host can execute
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Pierrick M Hanlet via Tech-talk
Sent: Thursday, June 15, 2023 6:08 AM
To: tech-talk at aps.anl.gov
Subject: cross-compiling v7.0.7
Greetings all,
Something broke, or I missed new instructions in building the modules in
v7.0.7 for cross-compiled platforms.
I'm building for several platforms.  The host build is fine, but when the cross-compiled platforms start building a new RELEASE.linux-x86_64.local is created with "EPICS_BASE = ", i.e.
empty.  I did not experience this with
v7.0.5.
Cheers,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Prev: Re: cross-compiling v7.0.7 Ralph Lange via Tech-talk
Next: RE: Issue installing asyn on CentOS 7 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025
Prev: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
Next: Re: cross-compiling v7.0.7 Pierrick M Hanlet via Tech-talk
ANJ, 15 Jun 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
